Some speaker driver measurements...
Old 6th March 2019, 12:59 PM   #241
454Casull is offline 454Casull  Canada
Thank you!
Old 11th March 2019, 03:52 PM   #242
HiFiCompass is offline HiFiCompass  Ukraine
The review of AudioTechnology 6" midwoofer 18H521706SD-4 has been added:
Review of AudioTechnology 18H521706SD-4 midwoofer | HiFiCompass
Old 13th March 2019, 07:34 PM   #243
Martigane is offline Martigane
This one looks great and reminds me of the satori mw16p. I think that its price is about double compared to satori.
I think that they have similar drivers with higher Qms.
Old 14th March 2019, 10:35 AM   #244
The measurements of ScanSpeak D2905/9700, D2905/9900 tweeters have been updated (only ETC, waterfall and step response):
ScanSpeak D2905/970000 | HiFiCompass
ScanSpeak D2905/990000 | HiFiCompass
The measurements of Accuton C30-6-024 have been fully updated:
Accuton C30-6-024 | HiFiCompass
Tha measurements of ScanSpeak D2908/714000 beryllium dome tweeter have been added:
ScanSpeak D2908/714000 | HiFiCompass
Old 14th March 2019, 09:28 PM   #245
Holy cow...
D2905/970000 looks good!!!
Old 14th March 2019, 09:59 PM   #246
Originally Posted by Martigane View Post
Holy cow...
Yes, exceptionally good!
Old 14th March 2019, 10:15 PM   #247
ScottG is offline ScottG  United States
I'd really like to see a motor (power handling) like that applied to their conventional dome (D2905/970000). (..I suppose the Revelator is similar to that.. but the 3rd harmonic discontinuity from 2nd at lower freq.s is not good.)
-what I find shocking is just how primitive the "enclosure" pathing/stuffing is - a BIG thanks for cracking-open that sucker! (..of course I'm not sure it had to be LITERALLY cracked-open.)
You might try various foam ppi (grades) instead of that cotton (..I'm assuming it's cotton, maybe it's a ceramic or glass fiber). I'm pretty sure they use foam for the Ellipticore.
http://www.troelsgravesen.dk/OVAL-1/...cor-6-1800.jpg
perspective is everything
Old 16th March 2019, 08:53 PM   #248
Thanks for the advice
It seems ScanSpeak do not long thinking just used in that beryllium model the motor from previous Revelator series tweeters - R2904/7000, D2904/7100, where it has special plastic supporting element for the aim:
- in the ring radiator version - to hold in place the bullet;
- in the dome version - to hold an underdome damping piece of felt.
In the 7140 there is no any of that elements, so, IMHO, the plastic "crab" was left there as a rudiment. It only inferes to the back pressure escape out of the under dome cavity.
In R2904, D2904 and all AirCirc tweeters are used the cotton pads, you are right.
In the Ellipticor ones it seems they use not the cotton but synthetic (maybe natural?) kind of felt. The back chamber cover in the Ellipticor made of a clear plastic and resonates very well
Old 16th March 2019, 09:25 PM   #249
..hmm, felt for the Ellipticore.
Yeah, I think you could get better subjective results with the right ppi foam (or even different layers of ppi foam). (..striving for similar damping/absorption but with much lower-loss/resistance (air-load to compliance) to the driver's motion.)
Are you sure that the 7140 isn't similar to the 7100? It looks like they both use the same outer-ring radiator design, and excursion is identical (..though mechanical resistance is half that of the 7100 - which is pretty awesome.)
Old 16th March 2019, 09:38 PM   #250
Yes, I should give ppi foam a try...
7140 has the same motor as 7100 but without a damping felt under the dome.
The lower Rms due the titanium former instead Alu one in 7100.
Some speaker driver measurements...Hide this!Advertise here!
Driver distortion measurements? maggiesnmacs Multi-Way 10 14th May 2016 06:28 PM
MA driver measurements tuxedocivic Full Range 67 13th April 2014 11:55 PM
Comparing REW, ARTA and CLIO in speaker driver and acoustic measurements panson_hk Equipment & Tools 28 9th April 2014 08:40 AM
Driver measurements Legis Multi-Way 0 12th October 2010 06:08 PM
Mic distance for driver measurements ted4412wilt Software Tools 5 17th December 2009 08:35 PM
Copyright ©1999-2019 diyAudio
