Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
#1181 |
#1182 |
HiFiCompass I really appreciate what you're doing, and you're doing an excellent job of it!
I missed Zaph's website for quite a while, and found your site via his recommendation. Cheers to discovering more gems. The MW19TX is a diamond for sure.
Unbaffled |
#1183 |
Seems odd that SB has the MW16TX-4 as higher sensitivity than the paper version, but HFC's results are the opposite?
19cm version is also more sensitive according to SB, but only a bit and in HFC's results are basically a wash. That's good, I had a 3-way in mind and didn't want to spend the money on the TX version for the woofer if there wasn't a benefit.
~Brandon Please help my waveguide and box construction research by donating to my gofundme via my website:Soma Sonus |
#1184 |
#1185 |
In order to become sane in an insane world, you must first become insane. |
#1186 |
I have an interesting question. Now that we have proper Beryllium and Diamond tweeters, does perusing plasma or using plasma makes sense - cost aside. ?
#1187 |
The review of the Satori TW29BNWG-4 beryllium dome tweeter with a waveguide:
Satori TW29BNWG-4 | HiFiCompass |
#1188 |
Many thanks, nice info on the BNWG -
This is Used in Jeff Bagby's last and self proclaimed best speaker, the Helios, the write up on the facebook site uses a prototype that was then put into production as this model iirc - The Helios Loudspeaker Kit - Meniscus Audio DIY Loudspeaker Project Pad |
#1189 |
Yes of course, we all know about that project
#1190 |
It looks good but at this price point i would expect more, i have this feeling that sb acoustics is rather sloppy, why do not they fix obvious flaws?
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Driver distortion measurements? | maggiesnmacs | Multi-Way | 10 | 14th May 2016 06:28 PM |
MA driver measurements | tuxedocivic | Full Range | 67 | 13th April 2014 11:55 PM |
Comparing REW, ARTA and CLIO in speaker driver and acoustic measurements | panson_hk | Equipment & Tools | 28 | 9th April 2014 08:40 AM |
Driver measurements | Legis | Multi-Way | 0 | 12th October 2010 06:08 PM |
Mic distance for driver measurements | ted4412wilt | Software Tools | 5 | 17th December 2009 08:35 PM |
New To Site? | Need Help? |
