Some speaker driver measurements...
Thread Tools
Old 21st January 2021, 05:41 PM   #1161
454Casull is offline 454Casull  Canada
Originally Posted by Scholl68 View Post
While I agree that the SB17NBAC has a much better price/performance ratio, and is probably just as good in the mids as those Textreme Satori, I don't think they are going to be quite as good in the low-end, because of their motor and suspension.
But that's what we are talking about. When you take the low end out of the equation, there's no real reason to pick the Satori over the NAC/NBAC.
Old 21st January 2021, 05:42 PM   #1162
Oneminde is offline Oneminde  Sweden
Oneminde's Avatar
This one.
In order to become sane in an insane world, you must first become insane.
Old 21st January 2021, 05:48 PM   #1163
Zvu is offline Zvu  Serbia
Zvu's Avatar
I'd really like to see SB15CRC30-4 measurements.
That one could be the winner on multiple fields.
Tesla; George Carlin
Old 21st January 2021, 05:51 PM   #1164
Scholl68 is offline Scholl68
I cannot be sure since I haven't listened to them, but probably true indeed, based on measurements.
Old 21st January 2021, 09:56 PM   #1165
briskly is offline briskly  United States
Some of these SB Acoustics drivers have off-axis suckouts in the midrange that match up with the near field dips. What is that null coming from?
Old 21st January 2021, 11:29 PM   #1166
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Like this one?
SB Acoustics SB17CRC35-4 | HiFiCompass
That dip at 1500Hz or so is usually a result of the half-roll surround, and it exists on-axis too. At some frequency the surround starts operating out of phase with the cone, causing some cancellation. The surround construction here has a lot to do with it, it's common in many speakers, not just SB. The wavy pro-style surround help here, or something extra crazy like what Purifi does or some Fostex models had complex surround construction to combat the effect.
The good news is that the dip is short band, and won't offended since it's a dip rather than a peak. People usually aren't put off by what they don't hear.
I'm not deaf, I'm just not listening.
Old 22nd January 2021, 12:36 AM   #1167
I did think it would be the surround/edge resonance almost immediately after posting, but the more important part I forgot to put in would be how to address the edge resonance. Cone reinforcement or injecting the surround with damping material?
And yes it is common, but the SB units are otherwise more well-behaved than most others in the midband that it stands out.
In any case, the off-axis dip limits convenient x-over transition wrt directivity. In that case, the Textreme behaves too much like the NAC cone as measured instead of the datasheet, which seemed a little poorly fit as a midrange driver.
Old 22nd January 2021, 04:40 AM   #1168
YSDR is offline YSDR  Hungary
The dip between 1-2 kHz is not the surround, it's a cone (edge?) flexing resonance of the soft cone, the hard cones doesn't have this behavior. Easy to see with comparison, just check the alu vs paper from the same driver family, everything is the same except the cone, hard vs soft, same as with SEAS (alu vs paper) drivers.
Old 22nd January 2021, 10:41 AM   #1169
Martigane is offline Martigane  Belgium
Yes, in my view, this 1.2k dip is a compound of edge resonance that affects not-so- rigid cones.
The suck-out in directivity aspect is interesting, i think it comes down to cone geommetry and dust cap.
Blog --- Objective and Subjective measurements/benchmarks; DIY builds, experimentations.
Old 22nd January 2021, 11:27 AM   #1170
tktran303 is offline tktran303  Australia
Thanks for the review Yevgeniy,
Looking forward to the MW19TX-4 review.
Some speaker driver measurements...Hide this!Advertise here!
Thread Tools
Driver distortion measurements? maggiesnmacs Multi-Way 10 14th May 2016 06:28 PM
MA driver measurements tuxedocivic Full Range 67 13th April 2014 11:55 PM
Comparing REW, ARTA and CLIO in speaker driver and acoustic measurements panson_hk Equipment & Tools 28 9th April 2014 08:40 AM
Driver measurements Legis Multi-Way 0 12th October 2010 06:08 PM
Mic distance for driver measurements ted4412wilt Software Tools 5 17th December 2009 08:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
