Has anyone Accuton C168-9-470 driver measurements?
Old 16th January 2018, 02:52 PM   #11
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Hadnt realised Troels crossed them so low. but that bodes well!
Had my GRT145's 6 months now, hooked up with SB Nac midwoofers in a simple standmount crossed at around 2.7khz They do sound great
Old 17th January 2018, 12:34 PM   #12
audiogurman is offline audiogurman  Ukraine
Banned
Thanks to all for the advices.☺
Old 18th January 2018, 06:25 PM   #13
Dave Bullet is offline Dave Bullet  New Zealand
C168 measurement as part of the Isiris project:
Isiris evolution to Osiris Jr? Summary of Isiris build and new update - Page 8
Old 24th January 2018, 05:50 PM   #14
The project above is awesome. Just read through the build thread ..
An accuton I hadnt spotted - underhung motor but this one is priced between the ferrite and the super expensive versions. Anyone tried it?
Accuton C173-6-197 Ceramic Bass / Midrange
Old 24th January 2018, 06:32 PM   #15
HiFiCompass is offline HiFiCompass  Ukraine
I hadn't worked with C173-6-197 but did with C220-6-227. These drivers share the same motor. C220-6-227 is very, very good driver, much better than other Accuton's ferrite motor drivers. This motor is the first of Accuton motors which has conducting ring in the motor, so low distortion. I think, C173-6-197 has the same properties.
Old 22nd February 2018, 04:14 PM   #16
A question, anyone think the C168 can cross ok to the new viawave ribbon ok? Maybe steeper than normal. The accuton THD and off axis response suggests a crossover point no higher than around 2250hz imo - Troels has crossed the viawave at 2200hz (2nd?)
Doable?
Old 22nd February 2018, 05:03 PM   #17
Sorry I forgot the measurements were for the woofer- I meant the C168-6-990
Old 11th October 2018, 02:38 AM   #18
Bingo1337 is offline Bingo1337  Germany
A bit late, but I have one measurement for you with that woofer in a 33 litre closed cabinet. here it comes:
File Type: png AS168 4 Ohm Messung 30 cm Abstand im 33 L Testgehäuse.png (162.5 KB, 65 views)
Old 11th October 2018, 12:43 PM   #19
lowmass is offline lowmass  United States
Doable?
YouTube
seems to suggest that anything below about 3500 may be an issue
Old 11th October 2018, 01:17 PM   #20
ATiRi
Troles used 2200 hz. BUT this will lower sensitivity of ribbon to get flat response. Not an issue in many systems. Looks like he got around 90 db sensativity at 2200 Hz
Has anyone Accuton C168-9-470 driver measurements?Hide this!Advertise here!
Wanted: Accuton C79-6 midrange driver pair Steve M Swap Meet 3 12th February 2016 07:17 PM
New speaker project. Mimmic Nolas? AER driver vs. RAAL+Accuton? LewinskiH01 Multi-Way 5 1st December 2014 05:05 PM
How to choose OBD2 OEM CarBrain C168 Scanner m1atlan Swap Meet 1 19th July 2013 01:15 AM
Accuton ceramic driver tests? 844 Multi-Way 4 11th May 2010 09:43 PM
accuton c90-t6 has anyone used this driver yet? mp006ltk Multi-Way 0 21st November 2005 02:01 AM
