DIY speakers for Audio(phile) Cafe Bar...Need help and support!
Old 11th January 2018, 08:03 PM   #51
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by Pano View Post
Oh. How did that work out?
Well. It was in place for many years until the restaurant closed.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th January 2018, 08:12 PM   #52
Cask05 is offline Cask05  United States
Cask05's Avatar
If you want to maximize the floor space and ensure good imaging, then mount the horns close to the ceiling (assuming flat ceiling, and higher ceilings could be better up to 5-6 metres). This avoids the issues with corner horns that you see in "The Loft" K-horns below--which required the added extensions of the Khorn top hats from the bass bins...
Keeping the audience out of the direct sound path and outside of 2 metres just about the speakers radially will ensure a stable imaging sound field. Doubling the number of woofers from two to four 15" diameter versions (using mid Qts drivers) will provide you the capability to elevate them, and eliminate the immediate need for subwoofers as shown in the orange SH-96/DBH-218 stack picture further above. If you want to have "touch and feel loudspeakers" with subwoofers, then you could do that if you place them in the room corners on the floor. Only a small amount of absorption next to the horn mouths on the side and front walls (~60 cm squares) should handle any midrange early reflections to assure good imaging.
Old 11th January 2018, 08:51 PM   #53
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
I note spiritland are near Kings Cross. That is the new trendy area. So much so that my employer has just moved their head office as was getting too expensive and the city of London proper was cheaper! I fear location will be far harder to sort than the sound system.
Old 11th January 2018, 09:31 PM   #54
Cask05's Avatar
That's usually the case with hi-fi venues--everyone's lease seems to always be ending and the owner looking for the next place to set his tent poles. Dave Mancuso apparently lost his lease more than once in NYC and actually went on hiatus with The Loft when new locations didn't work out.
The significant thing about Mancuso was apparently his continued emphasis on hi-fi sound and simplified signal path--no "special effects", queuing systems, beat matching, etc. In other words, no DJ or club stuff. He was reportedly a stickler for better playback devices: turntables, cartridges, clean and simple electronics, etc. It's an enduring formula that's survived to today.
Old 11th January 2018, 11:02 PM   #55
BlueWizard is offline BlueWizard  United States
In my opinion, you need Sweet speakers, nothing to bright.
As the provided videos show Jazz Coffee Shops are big in Japan. And they take their music seriously.
Given what I know of the UK (which admittedly is very little) what you consider a large room, the USA would consider a modest medium room. So, some sense of the actual room size is critical to the equipment.
Then we come to BUDGET? In Japan, they spend MANY thousands on the equipment and thousands more on content.
Then who is going to control the music, and I'm think along the line of a DJ here just to illustrate what I mean. People making and serving coffee and food, probably aren't in a position to keep fiddling with the Music. Then, how do you prevent the marginally employed teenagers working them from putting on DEATH METAL? Though there is certainly room for a range of music.
One option is to Network Stream using services like Spotify and Pandora. You can create long Playlists, or, unless I am mistaken, you can pick a genre (jazz, blues, ...) and it will stream a random selection of music from that genre. That is a way to keep the music flowing without the need for much monitoring.
Also, the selection of music on such streaming services is HUGE. Likely if anyone has a request, you can bring it up on Spotify and play it.
Also note that while Spotify and Pandora ... sound pretty good, there are CD quality streaming services like TIDAL, DEEZER, and similar. The bandwidth is higher, but still well within commonly available bandwidths.
Though NOTE, you do have to contact the Govt in the UK, or where ever, and get a license to publicly play music. I can't remember what the name of the organization in the UK is, though I've seen it a hundred times, but that is something you have to look into.
If you have the music on one end of the room, as shown in the videos provided by others, then those interested in music can sit closer, and those interested in conversation can sit farther away.
I would recommend somewhat large speaker playing with ease, rather than small speaker playing strained.
Fortunately, assuming the shop will be in the UK, the UK is a great place to by audio equipment, even despite the insanely high Value Added Tax. Good selection, good prices.
To make this a desirable place though, the audio equipment and speakers have to be WELL ABOVE average. No one want to go to a place and listen to a cheap stereo screaming away. It must have some finesse.
Just a few thoughts that occurred to me at the moment.
While we are at it, here is another Jazz Cafe in Japan using JBL Paragon speakers recently modified by Kenrick Sound in Japan. -
YouTube - Kenrick Sound - Paragon Delivery to ATRIUM Jazz Cafe
Steve/bluewizard
Old 12th January 2018, 02:24 PM   #56
zmyrna is offline zmyrna  United Kingdom
Originally Posted by chrisb View Post
OK, but gave you actually heard a pair of the Westminsters, or checked the enclosure drawings? But if they're not butch / steampunk enough, that's understandable.
Don't get me wrong; I really like the front horn loaded coaxial idea.
I would probably make it 4 way though; I do not like the idea of elaborate box design to distract every bit of bass out of a 2 way speaker.
Not into butch/steampunk
Like minimalist & utilitarian
Old 12th January 2018, 02:37 PM   #57
Cask05
those are excellent recommendations
synergy horns would be great for dispersion and headroom
i would probably add some remedy for sharp edges
adding a center channel is also a great idea, given there is enough space of course
Old 12th January 2018, 03:01 PM   #58
Good point
But I am actually trying to address that problem with providing something different.
So hopefully, enthusiasts would travel the extra mile to come and hang out in a music cafe that is in an area with cheaper rents. An old factory, warehouse conversion, railway arch etc...
Old 12th January 2018, 03:17 PM   #59
badman is offline badman  United States
badman's Avatar
Originally Posted by chris661 View Post
Let me know if you want to do anything around Sheffield.
Chris
Chris has Sheffield on lockdown, you will need to kiss the ring to get anything done in that neck of the woods.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 12th January 2018, 03:53 PM   #60
Originally Posted by manninen View Post
mono cafe, just one danley pole playing music
If I end up opening a cafe in a long and narrow space I might just do one big speaker
and name the cafe MONO
that would be really cool
Mr Sakuma's tiny cafe in Japan has a single Altec VOT as its main speaker YouTube
DIY speakers for Audio(phile) Cafe Bar...Need help and support!Hide this!Advertise here!
Where’s Café Blue? Peterm100 Music 0 26th December 2017 07:39 AM
LC Audio is not responding with support BMW850 Class D 3 25th November 2010 02:01 PM
Frugal-phile(tm) jag Everything Else 36 22nd July 2008 02:46 AM
Noticed that Nero ULTRA 7 Support 192KHz Audio alvaius Digital Source 0 21st January 2006 05:03 PM
Listening for jitter, s'phile test CD2 - ??? Matt MacBeth Digital Source 15 12th November 2002 11:30 PM
