Neutrik SpeakOn STX Chassis Connectors.  Male vs Female.
Old 5th January 2018, 05:01 AM   #1
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Default Neutrik SpeakOn STX Chassis Connectors. Male vs Female.
Is there any recommended convention regarding male vs female chassis mount connectors.
Usually for mains wiring you would go with female at the source, but this is audio and regular binding posts stick out there like dog's balls so.....
Just wondering if there is something I am missing?
The only thing I can think of is if a cable is wired differently at each end then maybe you want male and female at either end to avoid connecting the cable the wrong way.
Please enlighten me what Neutrik's intent is for the male/female chassis mount gender.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 5th January 2018, 05:11 AM   #2
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
The female might have more crosstalk.
OK.
Bad one.
Old 5th January 2018, 05:12 AM   #3
Hahaha
No. That was good.
Old 5th January 2018, 05:14 AM   #4
This may not be the best location for this question.
Probably more appropriately belongs in an amplifier forum.
Neutrik SpeakOn STX Chassis Connectors.  Male vs Female.Hide this!Advertise here!
Are you a male or female audiophile? wwenze The Lounge 5 6th May 2016 08:47 PM
SPEAKON 4 pole MALE to POWERCON female alexdjscz PA Systems 3 27th September 2013 09:54 PM
Need Female to RCA to Male CAMAC adapters bmenary Swap Meet 4 26th May 2013 11:14 AM
Connectors - male, female, and mating wwenze Everything Else 4 19th December 2012 06:59 PM
XLR connectors, male and female, which ones goes where? Kram Everything Else 23 30th December 2009 12:19 AM
