LX mini quest
LX mini quest
Old 17th December 2017, 03:48 PM   #21
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
I would recommend this...
-Run them with same polarity. If not, you'll get an unloading below Fs.
-I would also try a 2.5-way if you use 2 woofers. This will negate the distance between the woofers, and the lower woofer will not have to struggle to meet the widebander due to the distance they are separated. It just takes a largish I-core coil in series with the lower driver, and the L/driver series combo then in parallel to the other woofer, to facilitate the X.5 implementation.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 17th December 2017, 07:46 PM   #22
gin8330 is offline gin8330  Denmark
gin8330's Avatar
Thank you DonVK, sono tune ....what a brilliant idea I really like and a lot.
Old 17th December 2017, 08:37 PM   #23
DonVK is offline DonVK  Canada
DonVK's Avatar
No problem, it is unusual.
I also have a Omni OmniDirectional - work in progress that uses an 8" woofer like your LX mini. I found the bass was insufficient and was considering a new Omni design but decided to just add a separate subwoofer (SonoTube). Its actually better as you can position it in the room to minimize room modes.
Old 17th December 2017, 08:49 PM   #24
gin8330's Avatar
Thanks Wolf,
Haven't thought about driver unloading below Fs. Thank you.
Crossover ...do you mean same thing like this ?
Old 17th December 2017, 09:29 PM   #25
gin8330's Avatar
I bet you having god time with OmniDirectional project ...looks bloody god !
A bit jealous about those pipes you are using... i can`t get those in our tiny Denmark. I have to use real stuff like 3" heavy duty water pipe ( don't even let me start on a pricing ).
Omni directional design is a way to go with a speakers ,off course let not to forget about CBT Speakers .
Thinking about most impressive speaker designs and god execution of those it would be omni directional but not a boxy designs.
Just let us take Ohm Walsh , Duevel Sirius, B&O enter in a sound market when dinosaur has walked the earth, even they can`t came up with anything better as a last resort staying on a water surface , but with omnidirectional speaker design .
So we are on the right road DonVK !!
Old 17th December 2017, 09:47 PM   #26
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I'm intrigued by omni, I have dipoles which I like, I notice from your photos that the widebands are open back, are you getting dipole radiation from them?
Old 17th December 2017, 09:48 PM   #27
gin8330's Avatar
Have you ever heard or had RIPOL subwoofers ,DonVK ?
Old 17th December 2017, 09:58 PM   #28
DonVK's Avatar
I've never heard of them (RIPOL) previously so I had to look them up .
They look like a very interesting and compact design. It was described as a folded dipole. I was thinking of how to model it to predict its performance. A few articles described it as very good for music, but not punchy enough for Home Theatre. There were no measurements so that's speculation.
P.S. The sewer pipes are 4" PVC , are very common here, and cheap.
Old 17th December 2017, 10:07 PM   #29
gin8330's Avatar
Dipole designs are beautiful as well ! To me dipole-bi pole-omnidirectional is like a wardrobe for the same person. Clothing different but the person is the same. All it is about execution.
About those widebands...yes that was an idea .
Old 17th December 2017, 10:22 PM   #30
gin8330's Avatar
Yep RIPOL is a ride on a wilder side I guess and you absolutely right they are for listening music but not for opening doors and windows in a neighbours house.
Same links on RIPOL :
1. Strassacker: Speaker Building, Components
2. 4x 15" Need your support for bent sub baffle project
3. Jazzman's DIY Electrostatic Loudspeaker Page: Ripol Subwoofers:
LX mini questHide this!Advertise here!
Parafeed quest kirkmoore Tubes / Valves 1 26th April 2014 08:29 AM
quest for a cap.... CBS240 Parts 5 7th January 2010 08:38 PM
Tweeter Quest biovizier Multi-Way 8 17th July 2006 02:56 PM
The Quest millwood The Lounge 14 26th July 2003 04:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
