LX mini quest
LX mini quest
Old 17th December 2017, 09:10 AM   #11
gin8330 is offline gin8330  Denmark
gin8330's Avatar
Hej ven,
I can`t do that ...use the same xo/eq filters as Mr. Linkwitz' because he is using different drivers for his design,but....I have original xo/eq filters ( no miracle in those).
But my Xover has the same`ish cross point. Same times I'm enjoying 400 Hz crosspoint for drivers. Mr. Linkwitz' is genius to use full range driver and that makes all differences.
Old 17th December 2017, 09:10 AM   #12
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by gin8330 View Post
Does any one have tray such woofer configurations ( like in a drawing) ?
Wiring in phase and out of phase ?
How it affects sound ,specially out of phase wiring ?
I have used in phase wiring with back to back woofers and it gives force cancellation. If they were wired out of phase I would imagine you would get some kind of a vertical dipole effect and so some 360 degree cancellation. It would be simple and interesting to try both ways and tell us your results.
Old 17th December 2017, 09:28 AM   #13
gin8330's Avatar
Thanks scottjoplin,
Agree would be really interesting. Same how out of phase configuration makes me think about pipe volume as well ...volume at least will increase as one drivers Sd.
I don't remember where I red, but same one with such configuration ended up with half of speakers volume needed for driver.
Drivers are same how helping each other do a job as well .
Old 17th December 2017, 10:02 AM   #14
That sounds like you are describing an isobaric configuration, in my opinion the halving of the volume is the only real advantage of that
Old 17th December 2017, 01:38 PM   #15
DonVK is online now DonVK  Canada
DonVK's Avatar
And know is time for complete LXmini quest with all your help and advise.
I have laid hand on huge PVC pipes O.D. 315 mm.
Volume it can be from 49 to 66 liters and can accommodate 12.00’’ driver easily.
Mine plan is :
  • Incorporate Zobel network for woofer
  • Can be used 2 woofers in same pipe.
  • Woofer choice is Eminence BETA-12A-2 (good spec,reasonable price)
I'm assuming this is a subwoofer design, so you don't need a Zobel comp as the freq will always be very low and limited range.
What freq range are you expecting to cover (ie. 30-120Hz) ??
Why 2 drivers in a single pipe?
Old 17th December 2017, 02:05 PM   #16
I thought that, I asked him earlier, he said no, it's not a sub
Old 17th December 2017, 02:13 PM   #17
DonVK's Avatar
OK thanks, I missed that one.
Old 17th December 2017, 02:34 PM   #18
gin8330's Avatar
Thanks guys, with a design (incorporating second mid range woofer ) to the pipe,a goal is to get even more natural and relaxed bass with god musical definition of musical instruments...
to charge and move more air....I would describe as a "musical" bass (not a booming bass for car stereo) but bass where you can hear musician touching contrabass string.
At the same time would like to find physical drivers limit ( mine opinion is 12 ") where driver will reproduce musical instruments with minimum colouration.
Lets say one woofer will do 30 - 120 Hz range ( simple 1 order crossover) and second woofer do 120 - 1500 Hz range.
To make job easy for amplifiers incorporate Zobel network . I think BETA-12A-2 driver will benefit a lot from it.
All that is only mine thoughts and not based on practical experience.
Main reason behind starting this thread is to get practical experience from you. I'm sure same one was playing with such speaker configuration.
If I personally must choose subwoofer deferentially is will be RIPOL design.
Actually going build one after all festivity in a new year.
Old 17th December 2017, 03:08 PM   #19
gin8330's Avatar
Thank you scottjoplin,
You right that driver configuration is called an isobaric configuration and benefits of that is there. And those are really small potato in speaker design. Thanks
Old 17th December 2017, 03:27 PM   #20
DonVK's Avatar
If you want good bass you need to go down to 40Hz.
Why not have 2 chambers in your main 12" pipe. The top chamber would have your 8" woofer (>120Hz) and the bottom chamber has your 12" woofer (40-120Hz). You could make the bottom chamber a BassReflex or Bandpass. The low freq is omnidirectional anyways. SonoTube and SewerPipe BP6 Subwoofer
Alternatively, even with a single 12" you could get 40-400Hz and let the FullRange take >400Hz, keeping it a 2way system.
LX mini questHide this!Advertise here!
Parafeed quest kirkmoore Tubes / Valves 1 26th April 2014 08:29 AM
quest for a cap.... CBS240 Parts 5 7th January 2010 08:38 PM
Tweeter Quest biovizier Multi-Way 8 17th July 2006 02:56 PM
The Quest millwood The Lounge 14 26th July 2003 04:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
