Orthoacoustic simple two way Unity corner waveguide
Old 1st April 2019, 02:02 PM   #11
TNT is offline TNT  Sweden
The non longer accessible pictures - are they available elsewhere?
More distortion to the people!
Old 1st April 2019, 11:37 PM   #12
AllenB is offline AllenB  Australia
Tonal balance does come with simplified radiation. Congratulations on achieving this level.
Old 2nd April 2019, 08:20 AM   #13
Circlomanen is offline Circlomanen  Sweden
No. They are sadly all gone. I am going to make new measurements and post both pictures of the setup and spl-graphs soon (as in the coming month or two).
There is a thread on the Swedish site hififorum.se with all my ramblings and thoughts along the development process, but it is only text (in Swedish).
I only used Tom Danleys Unity and Stig Carlssons OA ideas and combined them into something slightly new.
Johannes
We live in a horizontal world, why use vertical topologies???
Old 2nd April 2019, 08:42 AM   #14
This is without EQ (red trace) and with EQ (yellow trace) measured with my Umik from across the room approximately 4 meters from the speaker.
I EQ mainly by ear, and check afterwards with REW and Umic, and this is where I usually end up. If I EQ to a flat level all the way up to 20 kHz the speaker sounds extremely bright and bass-shy, similar to other constant directivity horns or waveguides. A normal direct radiating speaker will reduce the radiation angle as the frequency increases. This speaker has a uniform dispersal pattern throughout its whole bandwidth, which tends to sound overly bright in a normal listening space.
The large waveguide increases the efficiency in the midrange from 180 Hz to 3,1 kHz, and this needs to be compensated with (DSP) EQ. I use my MiniDSP 2X4HD for crossover and EQ in this project.
Orthoacoustic simple two way Unity corner waveguideHide this!Advertise here!
3D printed 3-way Unity waveguide home audio speaker bwaslo Multi-Way 155 28th August 2019 10:16 PM
Simple discrete unity gain buffer tcpip Analog Line Level 143 20th November 2018 08:06 PM
Why could corner horn not be this simple? mashaffer Subwoofers 17 2nd December 2017 11:42 PM
Unity/RBI waveguide line array go94022 Multi-Way 5 14th August 2012 05:13 PM
Simple Line Level Mixer (Unity Gain) Noumenon Parts 3 30th December 2008 12:34 AM
Copyright ©1999-2019 diyAudio
