ABEC experts - help!
Old 28th November 2017, 01:43 AM   #11
DonVK is offline DonVK  Canada
DonVK's Avatar
Yes, that was cryptic now that I read it again. It was clear to me when I wrote it . That said, I'm not an expert on 3D mesh or gmsh.
Your original mesh file only has element type "2" =triangles, with 2 tags, and the expected 3 nodes and it was used exclusively. This is unusual, as there are no points (type=15, 1 node) or lines (type=1, 2 nodes). These other element types have different number of fields, so the number of columns will change. That's why I used a spreadsheet, I can import them using comma or space to separate the fields to make it easier to view this information. Hopefully that's clearer this time round. When I regenerated the mesh from step, I see element types of points, lines and triangles and ABEC is happy again. I attached the gmsh2 file spec so you can have a look.
I can't pinpoint specifics of a node or element causing the error. it may have been an open surface or an overlap. The ABEC error was occurring in both the inner and outer box, it was flagged and ABEC died on the outer box just because it was listed first in the file.
Old 28th November 2017, 01:52 AM   #12
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Have you read Gaga's post on the German forum? I translated them into English and they helped me a lot. ABEC is still an exceptionally difficult program to learn though.
Old 28th November 2017, 02:00 AM   #13
DonVK's Avatar
Do you mean the ones on DIY-HIFI-Forum - Powered by vBulletin ?
Old 28th November 2017, 02:11 AM   #14
Yes. This thread by Gaga:
Der ABEC Thread... - DIY-HIFI-Forum
Old 28th November 2017, 08:49 AM   #15
Gaga is offline Gaga  Europe
The meshing step, i.e. quality of the mesh is indeed critical for ABEC simulations.
From the thread mentioned by Patrick Batemen a stepwise description how to move from a CAD-file (STEP-file) to gmesh and to ABEC:
- Get a step-file from a CAD program, post #248.
- Get a mesh-file in gmesh, post #250.
- Import the mesh to ABEC, post #252.
There are some hints on favorable settings in gmesh in other posts, e.g. set element size (fineness of the mesh) in gmesh exclusively via 'Element Size Factor' or activate 'optimise hexa netgen' for meshing.
I can summarize my preferred settings here if interested (not necessarily the best for all applications though, but may be a good start).
Christoph
Old 28th November 2017, 11:20 AM   #16
natehansen66 is offline natehansen66  United States
Don - I'll take a look at what you're talking about later.
Yep! Found that a couple years ago and it has been a huge help. I've been going back through it a ton lately. Google translate works fine.
Christoph
I'd appreciate that.
Old 28th November 2017, 08:31 PM   #17
Just ask if something gets messed up with google translate in the ABEC thread - I'm happy to translate the respective parts.
Will summarize my preferred gmesh-settings here these days as well. Just busy right now...
Christoph
Old 29th November 2017, 07:12 PM   #18
OK, here is how I actually use Gmsh.
Disclaimer 1: I'm using version 3.0.4 for OSX, other versions might look a bit different.
Disclaimer 2: This may not be the best option to mesh for all situations. I just works fine for me.
Disclaimer 3: You probably know most of the steps. I explain in some detail anyway in order to make it clearer for ABEC beginners....
Here we go.
The respective *.step-file has been opened in Gmsh.
I then apply following settings choosing 'Tools' and 'Options'.
Options 1
Within the 'Options' Window I choose 'Mesh' - 'General' and
- 'MeshAdapt' as 2D algorithm:
ABEC experts - help!-2017-11-28-gmesh-options-1-png
Moreover I define the mesh-resolution here by giving a number for the 'Element size factor'. The lower the number, the higher the resolution of the mesh.
Options 2
Before meshing, I select 'Optimize quality of tetrahedra with Netgen' under 'Tools' - 'Options' - 'Mesh' - 'Advanced':
ABEC experts - help!-2017-11-28-gmesh-options-2-png
Mesh
ABEC experts - help!-2017-11-29-gmsh-2d-mesh-png
I do meshing via 'Mesh' - '2D'
Surface numbers
Surfaces labels can be seen choosing 'Surface labels' under 'Options' - 'Geometry' - 'Visibility'
ABEC experts - help!-2017-11-28-gmesh-surface-labels-png
You'll need these numbers in the 'Elements' Script in ABEC in order to reference the respective surfaces.
Save mesh:
ABEC experts - help!-2017-11-28-gmesh-save-mesh-png
Not much to comment here. The mesh file can then be imported to ABEC. The size of the 'XY.mesh' file gives a good indication on how long your computer will need to solve the file in ABEC.
Hope this helps.
Christoph
Old 29th November 2017, 10:07 PM   #19
Christoph - that helps a ton thanks! I've been flying pretty blind in Gmesh with only some very basic guidelines from the German forum and I probably misinterpreted something along the way
I just re-meshed my drawing with your suggestions and ABEC solved no problem.
Old 30th November 2017, 08:47 PM   #20
Happy to hear the description worked for you!
The posts on the use of Gmsh in the 'ABEC Thread' are indeed a bit confusing/messy. May be I should summarize the information on Gmsh in a new posting over there as well occasionally...
ABEC experts - help!Hide this!Advertise here!
ABEC + VACS jessep Software Tools 0 21st November 2017 11:44 AM
ABEC 3 sine143 Subwoofers 23 3rd August 2017 11:14 AM
ABEC problems gen0me Software Tools 1 20th July 2017 11:38 AM
Using ABEC 3.0 panson_hk Software Tools 0 23rd June 2017 03:46 AM
Need help from the experts bateman Multi-Way 1 22nd June 2003 02:29 AM
Copyright ©1999-2019 diyAudio
