Infinite Line Source: analysis
Old 19th June 2019, 08:28 AM   #461
onni is offline onni  Sweden
Thanks BYRTT and bolserst!
Included is a new version of the spreadsheet with possibility to set "Piston directivity" to "on". This calculates the directivity for a flat piston with set Sd (or manual input of diameter).
This is with 30 TC9s in a 2.6 m high room:
This plot is new, shows the phase inversion for off-axis response. Only complete inversions (180 degrees) are handled by the excelsheet, I have not implemented custom off-axis phase support.
As usual: download the *.mp4 and rename to *.zip and then unzip And if you find any errors, please tell me!
/Anton
Old 20th June 2019, 02:46 PM   #462
bolserst is offline bolserst  United States
bolserst's Avatar
Looks like the piston directivity calculations are working properly.
Two minor issues:
- For the “With Directivity” calculations on the [Resulting SPL] tab, the secondary floor reflection increment is getting turned on with the ceiling reflection flag rather than the secondary reflection flag
- When piston directivity is turned off, the phase reversals at high frequency due to directivity are still being included in the calculations
Infinite Line Source: analysisHide this!Advertise here!
Short Line Array (line source) build perceval Full Range 226 4th January 2015 02:08 PM
Achieving Optimum Line Array Performance Through Predictive Analysis Patrick Bateman Multi-Way 2 27th June 2014 11:45 AM
Shunyata DTCD power line analysis jackinnj Power Supplies 1 16th December 2011 12:30 AM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
line source diffraction david yost Multi-Way 8 5th June 2005 02:01 PM
Copyright ©1999-2019 diyAudio
