Infinite Line Source: analysis
Thanks BYRTT and bolserst!
Included is a new version of the spreadsheet with possibility to set "Piston directivity" to "on". This calculates the directivity for a flat piston with set Sd (or manual input of diameter).
This is with 30 TC9s in a 2.6 m high room:
This plot is new, shows the phase inversion for off-axis response. Only complete inversions (180 degrees) are handled by the excelsheet, I have not implemented custom off-axis phase support.
As usual: download the *.mp4 and rename to *.zip and then unzip :) And if you find any errors, please tell me!
/Anton
  • line array calc v3-100dir.mp4
    5.5 MB
Reactions: 1 user
Looks like the piston directivity calculations are working properly. :up:
Two minor issues:
- For the “With Directivity” calculations on the [Resulting SPL] tab, the secondary floor reflection increment is getting turned on with the ceiling reflection flag rather than the secondary reflection flag
- When piston directivity is turned off, the phase reversals at high frequency due to directivity are still being included in the calculations
Two minor issues:
Sorry for the late reply.
Well caught, here is an updated spreadsheet with fixes of the two mentioned problems. Rename to *.zip and unpack to access.
/Anton
  • line array calc v4-100dir.mp4
    5.2 MB
