The Reveal - Micro Budget Speaker Build
Old 16th November 2017, 12:24 AM   #1
Toid is offline Toid  United States
Default The Reveal - Micro Budget Speaker Build
I recently built a new set of Micro bookshelf speakers. My goal was to make something budget friendly and simple for beginners. SO I looked around for parts for a budget speaker. Here is what I came up with. I used the Dayton PC83-4 as minds and the Dayton ND20-4 for tweeters. The crossover is a simplistic 1st order crossover with a BSC circuit and a resistor on the tweeter. All in all the total cost of the build should be around $60 fo the components. I aam personally really happy with the sound. Check out the video for a quick build tutorial and sound test.
YouTube
Parts used:
Tweeter: Dayton Audio ND20FB-4 Rear-Mount 3/4" Soft Dome Neodymium Tweeter
Mid: Dayton Audio PC83-4 3" Full-Range Poly Cone Driver
Sub: GRS 10SW-4 10" Poly Cone Subwoofer 4 Ohm
Amp: Dayton Audio MCA2250E 2.1 Channel Class D Plate Amplifier
Crossover Components:
https://www.parts-express.com/27uf-1...citor--027-326
https://www.parts-express.com/dayton...sistor--004-10
https://www.parts-express.com/075mh-...ctor--269-2120
https://www.parts-express.com/dayton...-coil--257-032
https://www.parts-express.com/dayton...esistor--004-4
*These plans are for Personal use only. If you want to resell these, contact me first.
Updated Crossover: Click the image to open in full size.
Old 16th November 2017, 12:25 AM   #2
Pictures
Test Box with close-up pictures of the tweeter and mid
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Downfiring Sub and Amp pre-paint.
Final Speakers and Crossover diagram
Old 16th November 2017, 05:13 PM   #3
TudorTurtle is offline TudorTurtle  United States
I like the low cost requirement and the recessed mid-woofer design!
Old 18th November 2017, 04:12 PM   #4
Thank you! I appreciate that. I am still very impressed with their sound as well.
Old 18th November 2017, 08:58 PM   #5
adason is offline adason  United States
adason's Avatar
Can you post the measurements? Bookshelf mainly, on axis and off axis.
Old 19th November 2017, 04:40 AM   #6
I'll have to get back to you on that. But i will measure them when I can and post them.
Old 4th January 2019, 03:58 AM   #7
thirumalkumaran is offline thirumalkumaran  United Kingdom
Can you please share any updates on the MTM ported design?
Old 12th January 2019, 10:17 AM   #8
bsl100 is offline bsl100  India
Hi Toid... your tweeter crossover section doesn't seem to offer too much protection. How does it sound at higher volumes?
The Reveal - Micro Budget Speaker BuildHide this!Advertise here!
first budget MTM garage speaker build thread kcducttaper Multi-Way 15 11th October 2017 03:25 AM
First speaker build 2 way micro bookshelves - need crossover help username8611 Multi-Way 41 18th August 2014 06:50 AM
Budget Home Theatre Short Line Array Speaker Build oublie Multi-Way 4 25th June 2014 10:00 PM
Tony Gee's Low Budget Speaker - Build Thread mrevie Multi-Way 27 19th April 2011 12:40 AM
Low budget FR build for a cheap micro shelf stereo. 5wrms, what driver to go with? nobb Full Range 16 26th October 2009 06:15 AM
Copyright ©1999-2019 diyAudio
