Mmm, it appears this one has quite a lot of damping. Too bad, then this technique doesn't work anymore. There is not much of the expected ringing.Hello TBTL,
Thank you for your Reply, i tried this test quicky using the mic of laptop i would hold hand in the air in the name of physics if this worked. this is what i got.
BR
If you really need a number and you can live with it being inaccurate, something like 130 Hz seems to be the lowest frequency you measured.
Hello Ergo,
Could you please send me the link of the dial indicator you are refering. I dont knw if that the dial indicator adds a force to the plate too while making a meas.
Best Regards,
http://insize.com/products/tools/pdf/indicator-f/2308.pdf
Also - just found that latest version VituixCAD has also has a "Load impedance overlay", so a same method can apply.
... my concern is not to tune the passive radiator. i am looking for a 80/20 measurement method for the Kms/Cms of the surround mini passive radiator posted.
To what end other than tuning?
BTW, I missed a bit when typing earlier: Cms*rho*c^2*Sd^2=Vas
Hello ,
i created this setup using a Sauter digital dynamometer and a screw with of 1mm pitch.
BR
BR
