Compression horn driver for tweeter
Old 2nd October 2017, 07:09 AM   #1
goodguys is offline goodguys  United Kingdom
Default Compression horn driver for tweeter
Hi And thanks for reading this thread.
Can you recommend a compression horn driver for use as a tweeter, from 5khz up to 20khz.
I have a few jbl's, the 2447j (600) but they are only putting out midrange information. I want a driver with a higher frequency response, because i like the high sensitivity of compression horns. The jbl is 110db@1w/1m
Any recommendations?
Old 2nd October 2017, 07:28 AM   #2
marco_gea is offline marco_gea  Italy
No conventional compression driver is going to be at its best in your intended frequency range. Use a dedicated UHF driver with integral horn, like e.g. a ring radiator. If you want to stay with JBL, there's the 2405H, for instance.
Old 2nd October 2017, 07:32 AM   #3
Norelco is offline Norelco  Philippines
Try to look for JBL 2405 - http://www.jblpro.com/pub/obsolete/2405.pdf
Or JBL 2402 - http://www.jblpro.com/pub/obsolete/2402.pdf
Old 2nd October 2017, 01:07 PM   #4
Charles Darwin is offline Charles Darwin  United Kingdom
FaitalPRO | HF Drivers | FD371
Old 2nd October 2017, 01:14 PM   #5
Beyma CP 21/f - https://www.beyma.com/getpdf.php?pid=CP-21/F
Beyma CP 22 - https://www.beyma.com/getpdf.php?pid=CP-22
Selenium ST 400 - https://www.lautsprechershop.de/pdf/...st400_trio.pdf
Old 2nd October 2017, 04:28 PM   #6
Please help find a tweeter for 5000-20000
Same situation just with 2445 mids.
Just sayin'...
Old 2nd October 2017, 05:43 PM   #7
Jack Arnott is offline Jack Arnott  United States
BMS 4526HE on a BMS 4528 horn.
Old 3rd October 2017, 05:03 PM   #8
djn is offline djn  United States
djn's Avatar
I run the JBL 2441 on wood horns with the big *** Heil from 7khz on up. By the way, the big Heil is a horn.
Old 3rd October 2017, 07:40 PM   #9
djk is offline djk
R.I.P
djk's Avatar
http://usspeaker.com/images/faitalpr...-f-size475.gif
Candidates for the Darwin Award should not read this author.
Old 3rd October 2017, 07:52 PM   #10
freddi is offline freddi  United States
freddi's Avatar
wow - that HF108 looks like its worth its money - what horn made that graph? the spec sheet says
"Driver mounted on a 1" 50 x 40 Horn" - its that's the little aluminum tractrix, then I've a pair.
here's something crazy flat I measured - Peavey RX14 on its little round horn (like Eminence's APT80)
- its probably not as sensitive as that Faital driver. IIRC, this driver with horn sold for ~$28 on sale
at Partsexpress, and would be fun for things like a fake "Druid" arrangement.
note how it screws up on the Beta CX horn - also note, Iused just the 3.3uF cap for the round horn trace
- the cx had 0.33mH shunt
Compression horn driver for tweeterHide this!Advertise here!
horn attachment for compression horn driver. goodguys Multi-Way 19 10th January 2016 12:05 PM
How to chose a compression driver and a horn? djbfreak Full Range 40 15th August 2015 03:52 PM
Compression driver without horn Sanon Multi-Way 4 7th September 2010 03:27 PM
Compression driver to horn adaptors Botte Multi-Way 4 9th April 2010 02:11 AM
Why does a compression driver need a horn? Defo Multi-Way 39 6th January 2010 03:18 PM
Copyright ©1999-2019 diyAudio
