3 channel amp with woofer output ?
Old 1st October 2017, 06:01 AM   #1
ZipSnipe is offline ZipSnipe  United States
Default 3 channel amp with woofer output ?
I am getting ready to buy a 3 channel amp with woofer output. Will I still need a crossover?
The amp is 2x50 watts x100 watt sub and I plan on putting 3 @ 5watts speakers on each channel and a 50 watt sub all speakers are 8 ohm so the amp will be putting out half . So will I be alright with the speaker load? I always heard it was better to have more amp
Old 1st October 2017, 01:52 PM   #2
zimmer64 is offline zimmer64  Switzerland
zimmer64's Avatar
There are too many unknowns in your question. I guess you have to let us know, what amp you are buying and what the speakers are.
Old 1st October 2017, 06:56 PM   #3
Thanx for the reply. This is for a bluetooth column speaker build that I am doing here is a diagram with specs. I believe if I wire the 3 @20 ohm speakers parallel that I should end up with 5 ohms, correct me if I am wrong
Old 4th October 2017, 12:36 PM   #4
This is the amp I bought
Digital 2.1 Channel Amplifier Board Bluetooth USB Input 50W+50W Stereo 100W im | eBay
Old 4th October 2017, 01:56 PM   #5
giralfino is offline giralfino  Italy
giralfino's Avatar
You need a crossover, a high pass for the sub and a high pass for the satellites (*). This amp is basically simply 2 amps into one package: one amp for a stereo output and one amp bridged for a mono output.
As far as load, 3x 20 Ohm drivers connected in parallel are equivalent to a single 20/3= 6.7 Ohm load (forgetting about the fact that a driver is not a pure resistive load, and also that I've never seen a 20 Ohm driver).
Ralf
(*) If you plan to run the 3 drivers in parallel without any low pass filter, be aware that this is not a good idea because of comb filtering when the inter distance between the drivers is more that the wave length involved.
Old 4th October 2017, 03:44 PM   #6
MartyMG is offline MartyMG  United Kingdom
Hi, here's an interesting new plate amp version with adjustable low pass and presumably high pass for the satellites
Bluetooth 4.2 Digital 2.1 Channel Subwoofer Integrated Amplifier Speakers Board
Old 4th October 2017, 08:06 PM   #7
Ralf
Thanx for the reply, so it sounds like I need three crossovers one for each channel.
Yeah I never heard of 20 ohm speakers either but I have seen. 40 and 60 ohm speakers
Old 6th October 2017, 06:56 AM   #8
Pano is offline Pano  United States
Pano's Avatar
I have several amp boards similar to this one, tho not this exact model. Most have a low pass filter built in for the sub. You will know if this one does just by listening to it.
The main problem with the various boards is that although the amps are fine, the Bluetooth is super noisy. I hope yours is better.
Take the Speaker Voltage Test!
Old 7th October 2017, 05:11 AM   #9
Thanx I will let ya know if the bluetooth is noisey as this will be the main way I plan to use it. The build quality looked good on this board which is why I went with it
Old 7th October 2017, 12:09 PM   #10
Pano's Avatar
Please let us know. Always on the lookout for boards like this of good quality.
3 channel amp with woofer output ?Hide this!Advertise here!
CD Player XLR Output channel difference - 1/4 of volume in 1 channel? Loekie1 Digital Source 4 4th April 2016 10:19 PM
SSE sub woofer output. mudchute Tubelab 7 17th February 2014 02:49 PM
woofer + tweeter or full range on each channel fakeout Multi-Way 0 29th August 2012 02:57 AM
Can I have the sub woofer channel and the left and right channel as one? Boscoe Chip Amps 7 21st February 2010 05:56 PM
How to spilt one channel out from stereo for woofer chchyong89 Chip Amps 16 24th April 2009 01:11 PM
Copyright ©1999-2019 diyAudio
