tesla speaker spec's
Old 29th September 2017, 10:23 PM   #11
turk 182 is offline turk 182  Canada
so... on a scale of 1 to 10 how do these 666's rate as fullrangers?
i'm enjoying the first set on the original baffles stock just wired to my test amp!
Old 29th September 2017, 10:25 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
An OB is likely a good 1st bet. Wire the 2 in series and shunt 1 with a big cap.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th September 2017, 11:05 PM   #13
never been down the OB trail before.
any tips on baffle size and shape? there on 18 by 16 baffles now and give a fair show of themselves. placement i understand can make or break things no?
i've got some 100uf bipolar lytics for a quick listen.
Old 30th September 2017, 02:40 AM   #14
the 388 could be interesting by themselves if these specs are correct
Properties Input power RMS: 1,5 W
Input power MAX: 3 W
Impedance: 8 Ohm
Freq. range (Hz): 150-15000 Hz
Sensitivity (dB): 86 dB
Diameter: 100 mm
Mounting depth: 30 mm
Mounting hole: 100 mm
Basket material: Fe
Membrane material: papier
Weight:
0.18 kg
Old 4th October 2017, 02:24 AM   #15
well i guess i'll just try something to see what i get.
tesla speaker spec'sHide this!Advertise here!
Pioneer spec-4 no speaker relay Phantomrage Solid State 8 17th November 2016 02:03 PM
Damaged Tesla Speaker tansu Full Range 25 14th January 2015 12:01 PM
Speaker Tesla ARM9408 diagnost50 Swap Meet 1 1st December 2013 08:25 AM
Speaker spec terminology, what do these mean? sparkless Multi-Way 11 11th July 2009 02:40 AM
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 05:34 AM
Copyright ©1999-2019 diyAudio
