driver suggestions for 5" woofer
Old 30th September 2017, 08:08 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
It has been done more than once. Tricky to get right and it likely helps if custom drivers can be bought.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd October 2017, 12:49 AM   #22
Zarathu is offline Zarathu  United States
Originally Posted by wendelltate View Post
The original Nola speakers use a 5". The 6" Seas does sound nice. I just can't afford two more of those Seas. I. I do have two Aurum Cantus, AC130F1 from my Continuum speakers. I could use those in addition to the Seas drivers. I wonder how that would work...
Whenever you are using more than one speaker in the same range, you have to address potential comb filter distortion. This means that C(enter)T(o)C(enter) at the high cross of the two cannot exceed the size of the wavelength of the cross frequency. Otherwise, you won't like the dropouts. This exists where side by side or vertical placement.
I am building a system with 10 -2 inch Dayton Mid ranges in a 4 ways system. My cross is at 4000hz probably to a set of horns(the ctc measurement is different for horn throats than domes). The wavelength at 4000hz is 3.39 inches and my CTC distance between the speakers will remain below that.
If you already knew this, please ignore me.
Old 2nd October 2017, 05:11 AM   #23
mrkennyk is offline mrkennyk  United States
Could try these. SLS PRD100 Planar Ribbon Tweeter
Seas ER18RN woofer
Old 2nd October 2017, 06:21 AM   #24
frugal-phile(tm)
planet10's Avatar
Originally Posted by TheOnlyZarathu View Post
...This means that C(enter)T(o)C(enter) at the high cross of the two cannot exceed the size of the wavelength of the cross frequency.
wavelength.
dave
Old 2nd October 2017, 06:36 AM   #25
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Originally Posted by mrkennyk View Post
Two fantastic deals.. Do you think that tweet cd really cross at 3khz? I'm guessing it wd be better a little higher and with a steeper x/o It's still a bargain tho
Old 2nd October 2017, 06:53 AM   #26
With the peerless as a mid.......200-300hz and 5k-6k should work out.
Old 2nd October 2017, 01:00 PM   #27
Originally Posted by planet10 View Post
wavelength.
dave
That's excessive. You cannot hear it. Read Jim Griffin's Line Array paper. I have a line array built to the 1 wave length design, and I cannot hear any comb distortion at all.
IMO, one needs not to get too far into measurements that cannot be heard. IMO, the ultimate measurement is your own ear/brain combination.
Old 2nd October 2017, 01:49 PM   #28
zmyrna is offline zmyrna  United Kingdom
there are many good 5" drivers from dayton, peerless and sb acoustics around $20 each.
for tweeter, i would go for dayton AMT mini or its larger brother...
Old 2nd October 2017, 03:50 PM   #29
Dayton Dc28f is on sale at PE - also the ceramic coated tangband are good budget tweets
Old 2nd October 2017, 08:43 PM   #30
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
At the quality level which $9 retail suggests on that PRD100 planar tweeter, I would expect to buy 10 and then measure FR and try to match them up in tolerable pairs. I've been hoping someone else would take this on...?
driver suggestions for 5" wooferHide this!Advertise here!
12" Two Way Woofer Suggestions bassnkeys Multi-Way 6 3rd August 2015 08:23 PM
Suggestions for 4" Woofer for two way diypass Multi-Way 15 8th March 2013 07:53 AM
Driver suggestions for my new (sub)woofer project Mark.Clappers Subwoofers 6 8th May 2012 10:21 PM
8" woofer suggestions MunkeyQ Multi-Way 36 10th May 2011 09:27 PM
6 1/2" woofer suggestions -- MTM jmar Multi-Way 18 2nd November 2009 12:36 PM
Copyright ©1999-2019 diyAudio
