driver suggestions for 5" woofer
Old 28th September 2017, 11:14 PM   #11
OllBoll is offline OllBoll  Sweden
I'd get more of the H1480 L16RN-SL from the lxmini as they are extremely good on the low end. Great distortion performance as long as you don't massive xmax or need it to be cinema loud.
I'd steer away from pro midwoofers as they really aren't meant to handle bass. My 6nd430 for example which is advertised as a midwoofer optimized for low frequency is really a low midrange driver best kept to 200 hz and above.
Old 29th September 2017, 02:28 AM   #12
chrisb is offline chrisb
Dave, so just how pretty are they now, after another 6 hrs in the shop?
Old 29th September 2017, 02:34 AM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Lots Chris. I will drag the camera up and take pictures.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th September 2017, 03:14 AM   #14
system7 is offline system7  United Kingdom
system7's Avatar
A 5" woofer speaker is possibly the easiest speaker in the Universe. Most current drivers have a suitably low Qts around 0.3. H1216-08 CA15RLY
No time-alignment problems worth mentioning.
Cone breakup with a 5" is going to be up around 8kHz, which is well down in level with the usual 3kHz crossover. It all comes down to the tweeter for quality. I do think you should have a big reflex box around 12-15L. Reflex just adds a deeper octave of bass, albeit slow.
This sort of speaker doesn't go tremendously loud or deep. Forget about it for Disco use. But pleasant in a bedroom.
Best Regards from Steve in Portsmouth, UK.
Old 29th September 2017, 02:00 PM   #15
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
The SB15MFC30-8 is worth a mention.
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 29th September 2017, 02:26 PM   #16
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Lol so a 6+1 is the devils work, but 5+1 is ok.
Old 29th September 2017, 08:05 PM   #17
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Wendell, why are you looking for merely 5 inch drivers, as it appears you have more space on the baffle?
Old 29th September 2017, 08:21 PM   #18
wendelltate is offline wendelltate  United States
The original Nola speakers use a 5". The 6" Seas does sound nice. I just can't afford two more of those Seas. I. I do have two Aurum Cantus, AC130F1 from my Continuum speakers. I could use those in addition to the Seas drivers. I wonder how that would work...
Old 30th September 2017, 05:13 PM   #19
So... After some reading I see that it is not good to mix two different woofers in the same cabinet. I will just keep tweaking these city now.
Any suggestions on where to cross these? I am at 700 now. And can the woofer and the two full range speakers overlap each other? I have read that will cause a bump in frequency.
Old 30th September 2017, 05:18 PM   #20
I believe Rega have mixed 2 different woofers in their 2.5 ways. Correct if wrong
driver suggestions for 5" wooferHide this!Advertise here!
12" Two Way Woofer Suggestions bassnkeys Multi-Way 6 3rd August 2015 08:23 PM
Suggestions for 4" Woofer for two way diypass Multi-Way 15 8th March 2013 07:53 AM
Driver suggestions for my new (sub)woofer project Mark.Clappers Subwoofers 6 8th May 2012 10:21 PM
8" woofer suggestions MunkeyQ Multi-Way 36 10th May 2011 09:27 PM
6 1/2" woofer suggestions -- MTM jmar Multi-Way 18 2nd November 2009 12:36 PM
Copyright ©1999-2019 diyAudio
