Bass section
Bass section
Old 6th October 2017, 05:35 PM   #11
freddi is offline freddi  United States
freddi's Avatar
Bass section
although I don't think it would be louder down low than a regular 6th order assisted reflex , a Karlson 15 run per Exemplar makes an articulate subwoofer and an existing K15 can be modified with no cutting of the cabinet.
Two 3" ID PVC elbows would mount to a board which covers the port and that board screwed and sealed over K15's port. That drops the system tuning from the mid-upper 40's to around 29Hz. A low fs Altec 515 or 416 is used. Apply some boost at Fb, xover as usual where it sounds best with the upper speaker.
always brace K15's back panel. Even a single strut from the rear shelf is pretty effective. The wings can be easily braced with struts extending from the front shelf. (I've used 3.5" long pieces of dowel rod)
when built to spec, the mod is reversible, leaving all the goodness of K15
http://i.imgur.com/GDJegwz.jpg
http://www.6moons.com/industryfeatur.../exemplar2.jpg
a tall, folded ~20Hz path tapped pipe with good 15 would be interesting too. Driver needs to be offset to prevent a deep notch. This pipe for a cheap 12" is around 5 foot tall. That aperture is squeezed too much for playing sine wave but fine for music. Ask TB46 to calculate a 15" version if you've a woofer in mind.
http://i.imgur.com/Grsk1az.jpg
Bass sectionHide this!Advertise here!
Bass section design LewinskiH01 Multi-Way 133 3rd February 2015 03:51 PM
Tysen midbass/bass section pocoloco Subwoofers 11 26th October 2012 04:08 PM
Class D amplifer for Magnepan 3.6R bass section stolbovoy Class D 6 29th November 2010 12:31 AM
3 way design help with bi amp bass section djwhog Multi-Way 3 3rd November 2010 01:50 AM
bass section horn klipsh la scala jbsteeple Multi-Way 2 31st July 2006 05:28 PM
Copyright ©1999-2019 diyAudio
