Isobaric frequency limits?
Old 30th September 2017, 01:56 PM   #51
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Originally Posted by scottjoplin View Post
Have you considered a small sealed box and EQing, like, for instance a Linkwitz transform circuit or this Sub-Woofer Controller
Is it an active circuit and separate amp for the bass section?
ATM I'm buying a chinese valve amp
Old 30th September 2017, 02:00 PM   #52
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Yes, both are active, the ESP one is handy because it uses a particularly small cabinet to raise the resonant frequency and then EQs below.
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 30th September 2017, 02:05 PM   #53
To be honest I lack the skills for that. If there was a way of adding a passive EQ circuit to work with an existing amp, I'd be really interested.
But yes, using two or even 1 of these drivers in a sealed with enough EQ to hit 40hz f3 would be amazing. They only need around 25 litres each.
Old 30th September 2017, 02:30 PM   #54
There is such a thing as a passive line level crossover which could be an option, it still requires a separate amp for the woofers. TLS.org | Passive Line-Level Crossover
Old 3rd October 2017, 02:29 AM   #55
Ah I just figured out that's Kate Bush in your avatar!
Thanks for the help and the link. I suppose a separate sub amp would be an option. Ive got a Line Magnetic amp coming, so I kind of blew my budget..
Isobaric frequency limits?Hide this!Advertise here!
Private message limits jan.didden Forum Problems 33 27th March 2017 07:05 PM
What limits the power? Pentodo Solid State 13 10th September 2013 06:33 PM
Limits of Human Hearing thadman Multi-Way 18 7th October 2009 12:25 AM
limits in transient time metebalci Tubes / Valves 1 12th April 2004 08:57 AM
BZLS PS limits? protos Pass Labs 4 23rd January 2004 03:06 PM
Copyright ©1999-2019 diyAudio
