Isobaric frequency limits?
Old 23rd September 2017, 01:30 AM   #11
john k... is offline john k...  United States
john k...'s Avatar
Originally Posted by Bill poster View Post
Pretty sure two in parallel will give the same output but requires more power to do so ie 4 instead of 8 ohm load. Thats what I've read, correct me if wrong
Correct, but that is 3dB lower efficiency. 3dB more power in, same SPL out.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 23rd September 2017, 01:54 AM   #12
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Thanks for clearing that up. I agree that Isobarics don't generally make sense, 2 drivers etc.. just this driver normally requires such a big box it makes an argument for it, plus I can't see the equivalent in performance /isobaric cab
Old 23rd September 2017, 08:07 AM   #13
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
If mounted in reverse there is some canceling of non-linearity distortions
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 23rd September 2017, 11:30 AM   #14
john k...'s Avatar
That is pretty much a myth. I've analyzed the isobaric system and it depends on many factors. In general if there is reduction in distortion is it slight. However, some distortion components can actually increase slightly. It is a completely different situation that the calculation of even order distortion with a push-pull pair of conventional woofers (separate boxes). In the case of isolated push pull system it is the sum of the output of the two system and that the even order distortion is out of phase and cancels. In the case of an isobaric system it is not the isolated outputs that sum. It is two nonlinear devices directly interacting. The motion of one is a driving force to the other. The bottom line is that a blanket statement that isobaric system reduce distortion can not be made.
Old 23rd September 2017, 11:53 AM   #15
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
I have always wondered how the outer driver can handle the extra cone movement from double force... Having double radiating cone area would be more beneficial, but of cource the box gets bigger too.
Radikal aktivist AINOgradient speaker project
Old 23rd September 2017, 01:46 PM   #16
john k...'s Avatar
The pressure in the isobaric chamber actually varies as the pressure in the normal sized, single driver box. Thinks about it. The only way the outer driver will behave as if it is in a normal box is if the force on the back side is the same as it would be in a normal box. The rear driver sees a pressure force on the back side which is twice what it would be in a normal sized box, bot on the front side it sees the pressure in the isobaric volume, which is, again, the same as in a normal box. This both the front and rear drivers have the same net pressure force acting on them; that which they would have in a normal sized box. (Minor differences do occur.)
Old 26th September 2017, 03:26 PM   #17
Suppose a small upside is that a lower Q is easily attained with a slight increase in box volume and will lessen pressure on the back of that cone.
Why tf am I so obsessed with isobarics..
Old 26th September 2017, 06:29 PM   #18
Obsession is never good
Old 26th September 2017, 08:08 PM   #19
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Simply because the sound moves you like no other you can taste it. I went one step further and loaded the rear speaker into a transmission line. I drive it with a massive 7 watt class A JLH amp in a listening room of 300 cu m.
Kindest regards
Nico
Old 26th September 2017, 08:57 PM   #20
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
I had both Saras and Linn's big Isobariks. I loved the Saras, but they tended to eat amps. The big Isobariks were a bit easier to drive. Never liked the midrange on them, though, and finally moved to Magnepans. But God, what delicious bass those Isobariks had.
And hey, this is DIY. You should build whatever takes your fancy.
Jeff.
Isobaric frequency limits?Hide this!Advertise here!
Private message limits jan.didden Forum Problems 33 27th March 2017 07:05 PM
What limits the power? Pentodo Solid State 13 10th September 2013 06:33 PM
Limits of Human Hearing thadman Multi-Way 18 7th October 2009 12:25 AM
limits in transient time metebalci Tubes / Valves 1 12th April 2004 08:57 AM
BZLS PS limits? protos Pass Labs 4 23rd January 2004 03:06 PM
Copyright ©1999-2019 diyAudio
