I’m seriously considering matching this new tweeter, Peerless DX25BG60-04 1" Silk Dome Tweeter at PE with the Rival Acoustics R176-CP-08 Carbon/Pulp woofer.
This new tweeter looks quite nice but I am not familiar with Peerless quality. What are your thoughts?
Judging on overall build quality and performance I have to agree with wolf-teeth. I got the kevlar ones when they were on sale and will be getting some of the coated paper ones that are on sale now. The price seems low for drivers like this. I'm thinking its to get them known.
I see rival makes caps too. Have you tried them?
Very good drivers. They are somewhat new to the DIY sector, but up there with Wavecor, Usher, Scan Speak, in terms of quality and distortion measurements. I highly recommend them!
Wolf
What do you think of this one? R176-PV-08 Carbon/Pulp
I agree with Charlie Laub... Don't think the Peerless DX25B would be appropriate for low crossover applications. Visiting the Peerless spec sheet I see it does infer high power handling, but do not see anything about low crossover use. One big give away on the spec sheet, in addition to the tiny .1 MM peak Xmax is the test frequency range starts at 2,500 Hz.
There are a few Tymphany - Peerless designs, and expensive to boot that can play down to 1.5K. Take a look at the spec sheet for P/N BC25TG15-04.
You see a tweeter with a .6 MM peak Xmax and it's power handling (test) frequency range that starts at 1,100 Hz! Huge difference. I have used this tweeter and for under $15.00 each it is remarkable. I do suspect the DX25B is better, maybe much better from 2,500 Hz up.
There are a couple advantages with the DX 25B, slightly more SD, handle a bit more power above 2,500 Hz and a db or so more true efficiency.
It's likely NOT MUCH different than the P-8 or CP-8. From what I've been told, the coating on the cone is a different blend and that's about it.
Later,
Wolf
Later,
Wolf
What's with the price? It is unusually low for such a driver. Can't fight the feeling
- New Tweeter
