The Solstice gets positive reviews, and I am curious what the polar measurements look like. Anyone take measurements?
The Solstice is a basic two-way design, with both woofers working together in parallel over the same frequency range. The C-to-C distance between the tweeter and lower midbass is 11", and a basic Xdir simulation shows lobing which warns of soundstage changes when the listener is above/below the narrow center lobe.
Hi
Old thread..
How is the C to C from tweeter to lower midbass 11 inch ?
Can you please help me understand.
My calculations tell me it should be 11.89 inches assuming 5 mm space between drivers.
Inputs appreciated
Thanks !
