alpha 15 a and dayton audio ps 220-8 open baffle
i would like to try an Eminence alpha 15 A and a dayton audio ps 220-8 on an open baffle driven by a 60 watt per channel Kt 88 pull pull valve amp . should it be safe to run with no cross over ? should I protect the 8" driver ? Thank you for the help I dont want to blow it... all the horns i have tried are just too much also considering the tang band W8 1808
