Boenicke W5 clone
Boenicke W5 clone
Boenicke W5 clone Please consider donating to help us continue to serve you.
Old 14th February 2020, 06:14 PM   #51
LinuxGeek is offline LinuxGeek  Germany
Originally Posted by Dissi View Post
Beside the capacitor values, the crossover of Entonis also has one coil only. Here is another version of the crossover which corresponds much better to your picture:
Unfortunately I don't know the source of the schematic. I think the values in round brackets are the original ones. Later, they have been adjusted by ear.
No, this design was not very good. Tried it a while ago... In the same Thread was a better one.
Old 14th February 2020, 07:18 PM   #52
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Boenicke W5 clone
Originally Posted by ChrisABC View Post
...The Auris Poison 3…
Conceptually similar to Tysen V2. A well sorted diy project (using better, but pricier midTweeter) and 2 push-push bass drivers in an ML-TL. The push-push bass drivers have a huge advantage over a single side mounted woofer (we tried that in Tysen V1). 2 of the Silver Flute woofers cost about the same as a single Peerless (we use 2 in a different design) move more air, and goes lower.
A thread for Tysen and variations on WAW / FAST (quite a few other WAW in this thread, including the 2 examples of our WAW with Peerless woofers). Has a bit on the W5 as well,
I really need to get a picture now that they are nicely veneered.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th February 2020, 09:20 PM   #53
ChrisABC is offline ChrisABC  Canada
Boenicke W5- Gravelli
yet another sorta similar speaker-concrete enclosure don't drop it.
VIRTUOSO By Gravelli
Your wife says, " Dear could you move the speakers, I don't like where they are....What do you mean - you have to call your brother to move them?"
Old 14th February 2020, 10:28 PM   #54
pytha2008 is offline pytha2008  Germany
@LinuxGeek Hallo, hast du die Fräsung selbst gemacht? Ergo hast du die Daten als Dxf oder SVG ?
Wenn ja würdest du diese zur Verfügung stellen ? Komme ebenfalls aus NRW 33142
Vg klaus
Old 14th February 2020, 11:58 PM   #55
frugal-phile(tm)
planet10's Avatar
Boenicke W5 clone
Originally Posted by pytha2008 View Post
@LinuxGeek Hello, did you do the milling yourself? Ergo do you have the data as Dxf or SVG?
If so, would you provide them? Also come from NRW 33142
Vg klaus
English please
dave
diyAudio moderation team
Old 15th February 2020, 07:52 AM   #56
jimk04 is offline jimk04  United Kingdom
Interesting designs with the side fire woofer. Something o have considered to try to create a 'big speaker sound' without a large front baffle to aid WAF.
I have some TB W3-871 and SB15NRXC30-8 I may play with in a similar fashion to the Boenicke.
Are the drivers all in phase.? I would try without the ambience tweeter initially but I do like a spacious sound so that may prove invaluable.
Apart from P10 Dave's active design, I am surprised no one has tried a bi amped set up. What with the woofer running full range, one could use one channel to power that and another to power the circuit with the tweeter and FR?
Old 15th February 2020, 03:13 PM   #57
@dave :
Does push-push function well with the flute w14 membrane ? It's some kind of fabric and i did not know if its really sealed or air can go through the membrane...
Old 15th February 2020, 05:42 PM   #58
Here's some Boenicke W5 threads from other forums with completed projects:
(use Google Translate)
Boenicke W5 SE - Zvučnici - diyAudio.rs
Kleiner dan de MIMO, de WC2ND ... - Pagina 2 - forum.zelfbouwaudio.nl
Has Anyone Heard the Boenicke W5? - Page 2 - Headphones & Speakers - Audiophile Style
Boenicke W5 - kloon en kloon'isch' topic - forum.zelfbouwaudio.nl
filters ?
Boenicke W5 - kloon en kloon'isch' topic - Pagina 12 - forum.zelfbouwaudio.nl
Old 15th February 2020, 07:17 PM   #59
frugal-phile(tm)
planet10's Avatar
Boenicke W5 clone
Originally Posted by LinuxGeek View Post
@dave :
Yes. Some woofers you have to be careful mounting push-push, and if the drivers are on the side, the HF will be limited — our measure/XO designer guy pushed the passive XO up to 450 Hz (we biamped at 250 Hz).
The cones are a paper with high wool content. All the ones i have used have also been EnABLed.
dave
Old 16th February 2020, 07:44 PM   #60
correction for post # 41
"Bass 2.5mH Coil, 2.2 ufd Cap to Tang band W5-1138smf 2nd order"
should be 22 ufd cap on the woofer.
Boenicke W5 cloneHide this!Advertise here!
Boenicke W5 Kastanza Full Range 7 11th September 2017 05:13 AM
Heathkit w5 shawnds Tubes / Valves 11 16th January 2015 09:26 AM
FS: Drivers for JBL 250Ti clone (LE14, 108H clone, 104H-2 GordonW Swap Meet 10 20th May 2014 09:19 PM
W5-1611sa Jeb-D. Full Range 75 14th February 2013 07:14 PM
W5-1611sa same64 Full Range 40 22nd May 2012 11:16 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
