Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
Hello. I am curious about the use of car audio speakers in home audio projects. Can I use a Morel component system combined with a pair of Eminence alpha 15A woofers in an open baffle design? cons?
#2 |
The Eminence alpha 15A are designed for bass-mid or mid range in closed casing.
#3 |
Thanks for your answer... but I will be more specific... Is there any limitation in using a car audio component system for mids and highs in an open baffle speaker? The alphas already handle the bass perfectly. My concern is if the component's midbass can be used to handle the midrange and the tweeter the highs..
#4 |
#5 |
Thanks for your response... no problem with that... the alphas are also wired in parallel for a 4 ohm impedance and the amps that I am using can handle 4 ohm loads.. I am bi amping the system.. active xover between the alphas and the Morel Tempo midbass units and the passive xover between the midbass units and the tweeters..
#6 | |
Hallo landsman, I was almost ready to give up on endlessly trying to get my fellow speaker building enthusiasts to undersatnd about frontwave/backwave cancellation. Some will just NEVER "get it" Last edited by Scott L; 4th June 2017 at 04:44 PM. |
#7 |
Im sorry... maybe I do not understand.. are you saying or stating with your comment that the Alphas are not capable to be used as open baffle drivers or do you acknowledge the use?
#8 | |
I'm stating that several speaker builders do not understand front-to-back wave cancellation. |
#9 | |
Chris |
#10 |
Most cheap pa replacement woofers can also do that simply thanks to their smallish magnet, 40 or 50oz, giving high qts...
![]() https://www.parts-express.com/goldwo...oofer--290-384
"Fitz: I want to use an 8 inch woofer for more bass and a dipolar ribbon tweeter for sweet highs. And the enclosure should be a box with a vent, like everybody uses." S.L. Conversations with Fitz https://www.youtube.com/watch?v=59C7KZ5i42A ![]() |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Looking for Full Range for mid in Open Baffle | dcathro | Full Range | 33 | 30th January 2019 06:35 PM |
Celestion 12" bass mid Are the parameters any good open baffle | charlie2 | Full Range | 2 | 13th March 2015 12:05 AM |
mid/tweeter for open baffle project | el capitan | Full Range | 1 | 15th February 2011 03:27 PM |
planet10 and others: 40-1197 open baffle mid | jsaults | Full Range | 19 | 1st March 2007 07:11 PM |
please recommend an open baffle mid plan.. | Christof | Multi-Way | 1 | 25th April 2003 10:51 PM |
New To Site? | Need Help? |
