3D printing 1/2 of a waveguide
3D printing 1/2 of a waveguide Please consider donating to help us continue to serve you.
Old 22nd November 2019, 11:41 PM   #251
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by bwaslo View Post
Yup. That's why the Small Syns are in the living room here, and are what I listen to about 90% of the time. The large 3D Printed waveguide speakers do sound better, IMO, but wife doesn't like the idea of them in the room (and they're still smaller than most speakers audiophiles use!) Our living room is very small, so the 3DP waveguides are in the basement 'system', where it's dark, cold in winter, and noisy when HVC is running. Small Syns take up almost no floor space and don't dominate our little room.
Bill, you need to build a listening room in the basement! HT!? My basement was the same when I moved in, nothing, no noise control, ... But now I have a listening room to-the-max. It's soundproof! Imagine that! Took awhile, but it is doable.
Earl Geddes Gedlee Website
Old 22nd November 2019, 11:58 PM   #252
Brinkman is offline Brinkman  United States
Hi Bill, could the latest iteration of this printed horn (HF + Mids ports only) be used in a two-way? If so, what frequency are the mids crossing over to the woofers?
Old 23rd November 2019, 12:01 AM   #253
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
But your house is huge!
In Portland, 600' is considered "big"
Source: used to live in Portland, in 600'. Moved to Oregon City.
Old 23rd November 2019, 03:45 AM   #254
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
^^ like he said.
Also, my basement has 7' ceilings and I can't get more than about 15' from the furnace unless we have the whole HVAC setup reworked. So I just took it as a personal challenge to get something sounding good in a small space.
I do wish I had a big basement, though
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 23rd November 2019, 04:50 PM   #255
1hiep0 is offline 1hiep0  United States
Default updated
I changed the ports and add HP filter, woofers only.
Old 23rd November 2019, 05:28 PM   #256
I should have rephrased this; I understand that the crossover frequency is dependent on the interaction between the horn and woofer. What I meant to ask is an estimate of how low the unity waveguide holds a pattern with HF and mids only.
Old 23rd November 2019, 05:48 PM   #257
bwaslo's Avatar
About 700Hz.
Old 23rd November 2019, 06:31 PM   #258
Excellent, thank you!
3D printing 1/2 of a waveguideHide this!Advertise here!
3D-printing onni Multi-Way 233 22nd October 2019 02:03 AM
3D printing for diy-ing gpapag Everything Else 19 29th October 2016 08:21 AM
Modifying uFonken for 3D printing Jgtierney Full Range 6 14th January 2015 08:00 PM
Using 3D printing in DIY projects drfrink25 Equipment & Tools 10 24th July 2014 12:22 PM
Building a 15 " OS waveguide, with paper mache and 3d printing Tarkovsky Multi-Way 6 8th June 2013 12:42 AM
Copyright ©1999-2019 diyAudio
