Small format cone driver in horn thread
Old 11th August 2018, 10:34 PM   #101
freddi is offline freddi  United States
freddi's Avatar
what's a peppy little cone driver to mate with a 2" format horn? (I've Klipsch "K-260")
Old 12th August 2018, 05:14 AM   #102
hollowboy is offline hollowboy  Australia
Freddy, haven't you asked this before? Me, I'm using a small Tymphany / Peerless driver (NE65), but many other 2" and 3" full range alu cones are reported to work well over 500Hz to 15kHz (ish).
My system sensitivity & max output is enough for my needs (sensitivity is boosted by the narrow horn angle and 4ohm driver), but it is probably not enough for you or anyone else who wants it super loud.
I have an outdoor(battery powered) system that needs more efficiency, hence I use a real CD out there (JBL 2445 500Hz and up) ...but I'm considering changing that up by splitting the range: cone mids (maybe 400Hz to 4kHz) and CD highs.
I'm always considering ways to change it up, and only do 10% of them
This edit signature thingy is seriously hard to find
Old 4th January 2019, 10:09 AM   #103
frangus is offline frangus  Australia
Originally Posted by CFT View Post
Any update gentlemen?
Only that I am still listening to this system happily
I replaced the Hivi B2S with a B3S for a slight lift in efficiency. They sound sound similar enough once eqd appropriately
I have just put in an order for the SB acoustics full range driver which specs better in every way, hopefully it is the final change in the system!
Old 4th January 2019, 10:12 AM   #104
Forgot to mention that I have been alternating with a JMLC horn with radian 1.4 driver which is also a superb combo with very high SPL capability and plenty of dynamics
The fill range driver on the horn is less of that but has a smoother presentation and a nicer midrange. Im keeping both options
Old 4th January 2019, 11:38 AM   #105
CFT is offline CFT  United States
Have been looking forward to your reply. Thanks!
Please update us after trying the new speaker units.
Old 4th January 2019, 04:46 PM   #106
phivates is offline phivates  United States
Is there a detail of the throat shape when FR drivers are mounted to a wave guide? The need to match the CD exit angle would seem to be absent but experience rules over speculation.
Old 16th April 2019, 07:16 PM   #107
kec is offline kec  United States
kec's Avatar
Originally Posted by phivates View Post
How about you, KEC?
I didn't give up, just got sidetracked
I've been playing around with some more horns and 2 incher's.
This time the Eminence Alpha-2. Mated to a JBL clone I believe. 17.5" x 11" x 12" found here 11" x 17" ABS 2" Bolt-On Long Throw Horn 90deg x 40deg For Many 2" Exit Driver 647356202421 | eBay
Former Altec Employee ('78-'82)
Old 16th April 2019, 09:52 PM   #108
ErnieM is offline ErnieM  United States
Finally something on the Alpha-2. Looks good.
How does it hold up off-axis?
Old 18th April 2019, 01:37 AM   #109
kec's Avatar
Here you go...
Old 18th April 2019, 01:38 AM   #110
Cerik is offline Cerik
Cerik's Avatar
More details, please
Small format cone driver in horn threadHide this!Advertise here!
paper cone open frame driver for front horn hollowboy Full Range 45 11th May 2018 03:01 AM
The umpteenth large format coaxial driver thread Adolf Corkscrew Multi-Way 198 13th February 2018 11:32 PM
typical sensitivity of 4-5" cone driver on mid horn? freddi Multi-Way 24 25th October 2016 07:10 AM
Opinions on the best small paper cone full range driver above 400 hz? Bill poster Full Range 60 22nd July 2014 07:41 PM
Driver for AH-160hz horn: cd vs cone? bvan Multi-Way 30 27th November 2012 10:10 AM
Copyright ©1999-2019 diyAudio
