Help needed - understanding crossovers
Thread Tools
Old 25th March 2017, 01:51 PM   #31
jazbo8 is offline jazbo8
diyAudio Moderator Emeritus
jazbo8's Avatar
giralfino already gave you the answer, please re-read the post carefully. Also do not start multiple threads on the same topic, which is against the Forum Rules.
Old 25th March 2017, 06:48 PM   #32
bullittstang is online now bullittstang  United States
Originally Posted by dreamerm6 View Post
Is it too expensive? Too heavy? Too complicated? Surely amplified sound can still be managed electronically?
Yes to all those. To get 3rd order or 4th order electrical it would be HUGE, HEAVY and cost Hundreds for each way.
Electronically is the only economic and size way and once you past the amp, the is no inexpensive way to do it electrically.
Then you would still need to add phase and impedance compensation, so a whole other complication.
Figure out your mic and REW, get some way to take impedance and then take some in-box measurements, otherwise all you are doing is guessing on a XO.
Sent from my iPhone using Tapatalk
Old 25th March 2017, 06:53 PM   #33
dreamerm6 is offline dreamerm6
Thank you! Thats what I wanted to know. Yes I will do tests with Mic and software before I complete the XO. Just getting the basic information sorted before I start building the XO.
Old 25th March 2017, 07:14 PM   #34
PeteMcK is offline PeteMcK
I disagree with those who say on-line calculators shouldn't be used - Like any tool, you just need to know how to use them. Going back to the first post, you have used 'nominal' values of impedance - first mistake. Get hold of the manufacturer's data sheet, and read off the impedance of the driver at your chosen crossover frequency, and use that in the calculator. If you can't get data sheets, then you'll need to run an impedance plot yourself, this is possible by using the LIMP module of ARTA and a simple jig. Design of 3 way crossovers can be simplified by making the woofer-mid xover point the same as the baffle step frequency.
"A Fenderr Telecasterr has mair penetration than an AK47" - Alex Harvey
Old 25th March 2017, 07:22 PM   #35
That makes sense off course, the speakers might be 7.5ohm etc! Thank you I actually never thought of that! I will measure them with my multimeter to see what they really are. Also obviously the calculator gives you a good reference to what you can expect to use component wise, unless you get drivers which really fall out of the bus giving weird responces etc.
Old 25th March 2017, 07:43 PM   #36
measure with a multimeter is pointless, you'll only get Re. read my sig, a proper impedance plot involves doing a frequency sweep of the driver and producing a graph of impedance vs. frequency. Look at a speaker data sheet to get the idea
Old 25th March 2017, 07:47 PM   #37
I get you now! You are talking about this :
Help needed - understanding crossovers-ohmvsfreq-jpg
Old 26th March 2017, 12:25 AM   #38
Old 26th March 2017, 03:32 AM   #39
steveu is offline steveu  United States
The signal from an amp to a speaker is a POWER signal. Any crossover that handles such a signal has to operate at that power level. Electronic crossovers operate at line level, ie milli-watts. Be sure you understand that electronics including amplifies do not amplify, they carve a bigger copy out of their power supplies and hence their output is limited to the size of that power supply. The signal power output of any electronic device does not come from the signal input.
Old 26th March 2017, 08:53 AM   #40
Thank you thank you!
  Reply to this post
Help needed - understanding crossoversHide this!Advertise here!
Thread Tools
filters/crossovers a little understanding needed charlie2 Multi-Way 3 19th February 2015 01:33 PM
Need some help understanding Vrystaat Power Supplies 4 4th July 2013 03:30 PM
Need some help understanding high & low pass filters & crossovers Haz Multi-Way 13 12th May 2012 02:03 AM
Help needed understanding component values. cbj591 Tubes / Valves 15 5th August 2010 09:23 PM
Amp understanding / help bear-hifi Solid State 2 7th February 2006 03:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
