Improve Cerwin Vega E715
Old 1st January 2017, 10:00 PM   #1
Matyam is offline Matyam  United Kingdom
Default Improve Cerwin Vega E715
Hi everyone I use some cv e 715 mainly for home theatre duties because of there 15"woofer air pushing duties,but I'm finding I could need a bit more clarity on the mid range. and perhaps the tweeters .I have removed drivers etc and there is padding on side and back walls with bracing half way up cabinet.Now I realize they are what they are but anyone who can chime in and help this novice with possible improvements to cabinets and replacement drivers of a higher quality that would be appreciated thanks.
Old 1st January 2017, 10:56 PM   #2
EarlK is offline EarlK  Canada
What are your budget expectations (for any upgrade)?
Are you willing to alter ( cut into the face of ) the cabinets?
Do they have an existing dog-house ( sealed, mini enclosure ) for the current mid-range driver?
Old 1st January 2017, 11:40 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
My CVs
Use a sealed back midrange...so no enclosure needed.
Have the 12" woofers run fullrange without a crossover
Have some carpet padding on 3 walls
I use them as subwoofers and integral stands for my DIY mains
Replacing drivers is a fool's errand. You will have difficulty sourcing midranges and tweeters sensitive enough to match the woofers. Even if you can, you will need to measure the new drivers and redesign the crossover.
Sell them to some kid for ~1/2 what you paid and buy something better?
If you want to use what you have, look into the "econowave".
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 2nd January 2017, 11:51 AM   #4
No problem chucking couple hundred pounds per side at a improvement as eventually won like to build something but got to start somewhere.
Old 2nd January 2017, 12:13 PM   #5
Originally Posted by Ron E View Post
My CVs
Maybe ( a fool's errand ), but ( since every-time I get to hear the Audax PR170 it makes me smile & therefore ) I figure everyone else ( with an itch ) should get to own a pair ( even in a franken-speaker ) to begin their audio journey to somewhere better .
The venerable EAW FR153 could serve as an upgrade path ( with the components vertically arrayed ).
This mid will offer out-standing high-efficiency mids @ 400hz to 4K ( when put into a small sub-enclosure //> think insulation-packed, approx 6" diameter, card-board sono-tube ).
Of course, there's the problem of the existing crossover / but if a fellow isn't too picky at this juncture ( & is a CV user going to be ?? ) then I'd just wire it up and have a listen ( ie; nothing ventured, nothing gained & all that ).
Old 2nd January 2017, 12:42 PM   #6
The EAW 153 ( plus a few other models ) uses a small round waveguide ( with a compression driver behind it ).
If you look around ( on your side of the Atlantic ) you might find this little guy to retro-fit to your CVs.
This is available in N.A. at FullCompass.com, as part# 504002 .
That guide ( or similar ) driven by something like the Peerless Compression Driver ( crossed around 2.5K ) will offer a very good HT experience ( IMO, after a network gets created & dialed in ).
PS; that Audax PR170MO, is available in the UK from FalconAcoustics.
Old 2nd January 2017, 05:55 PM   #7
Ron E's Avatar
I honestly think putting a couple hundred pounds to a kit will give a better chance of success / satisfaction. I already mentioned the "Econowave project" as a means of improving what you have.
Old 2nd January 2017, 06:35 PM   #8
Thanks guys i guess frankenspeaker it probably will be as I have gone through 6.5" to 10" kefs up to these 15" speakers and even though they are what they are I prefer there air moving abilities for home theatre after wearing out my sub twice before ,with my style music even with a sub .The mid range is in its own sealed space and I have no problem adapting the box for a higher quality mid,trying to find out crossover of existing mid so to not have to alter crossover yet.Will check out to see if I can match up mids with your example.The econwave kit looks great but the 15" Vega drivers are unfortunately a must till I could find a better one of them as well.
Old 2nd January 2017, 07:02 PM   #9
Ron E's Avatar
The econowave could likely use the Vega 15. Worth looking into.
Old 2nd January 2017, 07:48 PM   #10
This PRV waveguide ( 152i clone ) is sonically nice & can look good over a 15" woofer ( & through the economics of eBay's "Global Shipping System" ) can now be acquired in most countries at reasonable cost.
Search eBay for the "Parts Express" store / then "PRV" and then you can find out the cost to have a pair sent to the UK.
An externally hosted image should be here but it is no longer accessible. Please upload images instead of linking to them to prevent this.
Buy a pair of B&C de250's locally ( & then use a Zilch econowave network designed for this horn/driver combo and live with the "wrong woofer" lash-up ).
Improve Cerwin Vega E715Hide this!Advertise here!
cerwin vega's millertyms Multi-Way 1 13th July 2009 03:29 PM
Cerwin-Vega D-7's sorenj07 Multi-Way 0 9th February 2008 01:10 AM
Cerwin Vega aperrado Subwoofers 4 1st February 2008 05:52 PM
Cerwin Vega D-7 sorenj07 Multi-Way 2 3rd March 2007 07:16 PM
Cerwin Vega! jamerick Subwoofers 4 6th January 2005 01:35 AM
Copyright ©1999-2019 diyAudio
