Klipsch Forte Crossover
Klipsch Forte Crossover Please consider donating to help us continue to serve you.
Old 25th December 2016, 06:59 PM   #1
Chuckstereo is offline Chuckstereo  United States
Default Klipsch Forte Crossover
Merry Christmas and Happy Holiday.
This is my first time on diyAudio and my first time building this Klipsch Forte crossover. The crossover build kit along with midrange and tweeter diaphragm upgrades for the Forte was purchased from Critespeakers.com.
I have followed the Klipsch Forte crossover diagram and then laid out my board designed that follows the original design and after putting the speaker back together, I've found the soundstage is not present like it was before I've replaced the original crossover.
I wanted to see if anyone can see a fault with my crossover rebuild or maybe a way that I can test the crossover build.
Thank you, Chuck
Old 15th February 2020, 12:14 AM   #2
Topping is offline Topping  United States
A 1uf Capacitor on the mid driver is definitely not good.
The mids can be improved with 3.0uf and 6ohm resistor 20 watt.
Old 15th February 2020, 01:05 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
moved to the multi-way forum.
dave
diyAudio moderation team
Old 15th February 2020, 01:13 AM   #4
frugal-phile(tm)
planet10's Avatar
The 1uF cap is the high pass on the mid. If it is a nominal 8Ω driver that means response below about 20kHz is being rolled off at 6dB /octvave. If it was 10uF it would probably be in the ballpark for a 4Ω mid driver.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th February 2020, 01:21 AM   #5
AllenB is offline AllenB  Australia
AllenB's Avatar
Do both sides sound the same level, and same response? Does each driver sound reasonably balanced with the others? Have you tried changing polarities? Can you measure?
Old 16th February 2020, 08:43 AM   #6
Get the midrange out of the woofer inductor
Old 16th February 2020, 09:21 AM   #7
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Not that it's relevant anymore to OP, but can someone explain who has designed the upgrade xo filter? Original xo frequencies are about 650Hz and 5.2kHz.
Old 16th February 2020, 05:10 PM   #8
Can someone give a explanation of a speaker transformer.... i would bypass that mess and locate a small tweeter(ground shunt)INDUCTOR , for the midrange .35mh oh so is fine , preceded by 4uf capacitor. Adjust the output with a 20watt ground resistor(like the tweeter is using 40ohm) anywhere from 15ohm to 50ohm. If you play them loud consider putting midrange driver back in standard PHASE.now the forte 1 will sound fantastic.
cheers everyone.
Old 16th February 2020, 07:44 PM   #9
frugal-phile(tm)
planet10's Avatar
Each leg of the circuit is completely separate. The woofer inductor does not affect the midrange.
dave
Old 16th February 2020, 07:51 PM   #10
frugal-phile(tm)
planet10's Avatar
I beleive it is an autoformer used like an L-Pad to adjust the output level. Commonly seen in Tannoy XOs and in the LS3/5A as well
Klipsch Forte Crossover-chartwell-ls3_5a_xo-png
dave
Klipsch Forte CrossoverHide this!Advertise here!
Klipsch crossover pioneer spec4 Multi-Way 0 29th January 2015 02:27 PM
Klipsch Forte ll in oiled oak for sale... moray james Swap Meet 0 2nd February 2011 06:37 PM
Upgrading a pair of Klipsch Forte wapo54001 Multi-Way 4 13th October 2010 02:59 AM
Speakers to replace Klipsch Forte II's Glowbug Multi-Way 2 21st December 2008 06:54 PM
Wilmslow Forte crossover question michaelpage26 Multi-Way 2 11th June 2004 05:11 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
