Piezo VS voice coil tweeters
Old 15th June 2019, 07:09 AM   #91
norman bates is offline norman bates  United States
norman bates's Avatar
My results with quality motorola were superb.
Motorola ksn 1038a.
It has a bad resonance at 4.5khz, but I was using it with 24db LR active crossover at 5khz and up. Turning crossover point down, it got in your face buzzy fast. Think I had a 30ohm resistor in series with it too.
Otherwise, passively, you need to transformer couple it (with the 8ohm tap towards the amp), add a zobel, add a resistor to bring (changing Z) close to the 25w tap (I think), and also notch out a resonance (somewhat).
Freddyi is the now expert and measured super low distortion using ksn 1016 piezo.
You can find many posts by him here and audioasylum.com
I saw djk's piezo array (5 x ksn 1016a Motorola), yes, it was the klipsch 1900 looking one.
Old 17th June 2019, 04:05 AM   #92
NoCompulsoryRegistr is offline NoCompulsoryRegistr
Default PIEZO ARE GREAT SOUND MACHINES :MOTOROLA is the best >>experienced !
The quality of a piezo speaker is directly proportional to the size and quality of the piezo element used :ORIGINAL Motorola (now PIEZOSOURCE >>> Piezo Source, Inc. ),Goldwood (https://www.goldwood.com/goldwood/mi...iezo-tweeters/ )
and MONACOR (MONACOR: Search Results "piezo" ) with the same GOOD QUALITY 22mm. diameter piezo element inside for ALL the models:They are the best brands on the market.
Having tried them personally (and checked the internal quality), what I write is the truth experienced, no prejudices or chatter!
Bigger the piezo element (the active metallized part on the ceramic!) and the precision of the assembly, enormously better the sound (HORN type used is a separate matter !).
ORIGINAL Piezo Motorola are excellent in every aspect and for example, there is no piezo driver on the market bigger and more powerful than the KSN1188A.
Aganin :
Stupidity is to use piezo tweeter (or driver) without proper crossover :Using it, You get exceptional results and the sound played by a piezo becomes of higher quality than a mobile voice coil tweeter !
It is always necessary to investigate, to experience and to try : especially with electronics and physics but unexpected results can be obtained.
In the life , there is a lot to discover !
Old 17th June 2019, 04:49 AM   #93
Default MONACOR PIEZO are good quality and with BETTER SOUND AND CONSTRUCTION THAN "GRS"brand
Having tested numerous drivers and tweeters piezo in various configurations, with and without crossover ,with or without impedance transformer, I found that :
Using the same HORN, the tweeter piezo branded "MONACOR" model MPT165 is considerably superior in both:In the sound reproduced and constructively than the brand "GRS" model PZ1165 .Although , the diameter of the piezo element is the same (22 mm.)
File Type: jpg grs-pz1165-4-3-8-piezo-horn-tweeter-similar-to-ksn.jpg (379.9 KB, 187 views)
Old 16th September 2019, 08:47 PM   #94
Freedom666 is offline Freedom666  Germany
Who is interested in measurements - on my blog there are Piezo Tweeters with a 12 db crossover. Try google translation because its in german.
Tweeter with 100 ohm in parallel, 027 mfd an 1,36mh, 12 db crossover with measurement.
I covered after the measurement the diaphragm with aluminium foil.
Measurement without crossover (blue)
Measurement with 100 ohm parallel and 0,27mfd capacitor (red line)
Measurement with 100 ohm parallel directly between hot and ground of the tweeter and 0,27 mfd capacitor and 1,36mh in parallel
Dragan from Germany
Old 17th September 2019, 01:00 AM   #95
fullrage is offline fullrage  United States
Talking PIEZO tweeter-n-waveguide,
howdy yall, who, sells the "monacor" brand?
Old 18th September 2019, 02:11 PM   #96
Default piezo horn
rereading my last mess. leaves me some what unclear. What i'm asking is any one aware of a company state side that deals with piezo's ? Parts express carries GRS,and GOLDWOOD, i'm hoping for another source, hopefully brand new! and of a better build quality- something as close to the MOTOROLA 1140a as posible?
Old 18th September 2019, 08:31 PM   #97
TBTL is offline TBTL  Germany
Just curious, has anyone tried using a DSP to flatten the frequency response of a cheap piezo? How did that sound?
Old 23rd September 2019, 02:13 PM   #98
Could be that dsp power can help to bring resonances down in piezo drivers or make the response better not only in the frequency response but also in the waterfall decay. But I did not try this.
As my use of piezos is only for the indirect sound field their frequency response is not so important.
My piezos have no damping behind the paper diaphragm and have no damping of the piezo itself by some 1mm thick rubber (Motorola piezos had some damping here.)
Maybe you could get some Monacor Piezos from Ebay directly from Germany.
The biggest difference in sound you get from covering paper diphragms with aluminium foil. I do this nearly on all my loudspeaker drivers. This is mainly due to a change in impulse response. Original drivers are poor in this discipline.
Piezo VS voice coil tweetersHide this!Advertise here!
Morel voice coil replacements / new "CAT" tweeters... critofur Multi-Way 31 13th October 2009 03:41 AM
Single Voice Coil Vs Double Voice Coil Subwoofer kASD Car Audio 6 12th April 2007 07:36 AM
ASV voice coil ? Nihilist Multi-Way 4 1st October 2006 08:16 PM
an amp for each voice coil? speekergeek Multi-Way 1 12th December 2003 03:31 AM
blown voice coil krimet420 Multi-Way 3 10th December 2003 03:30 PM
Copyright ©1999-2019 diyAudio
