T Line Waveguide inspired build help
Thread Tools
Old 10th December 2016, 11:10 AM   #1
land61 is offline land61
Default T Line Waveguide inspired build help
Hello,
I've always liked the bose waveguide but realize it is a product based on some fundamentals that revolve around the tline design of speaker enclosure
So i set about building my own project stereo tline box.
Any comments on the choices I have made are appreciated.
So
2 scanspeak 12w/8524g00 8ohm fs 52Hz 40wrms
2 Monacor DT-99 8ohm rec x over 2500hz 40wrms
6db monacor xover at 2.5Khz
Old 10th December 2016, 11:29 AM   #2
More info, the box will house left and right speaker sets and have a folded tl
fs=52hz so a 1/4 wave is 1.65m
the design of the box is mdf, I have built the box and am just waiting for the scanspeak speakers
The amp is a sure 50w unit
pictures to follow
I am predicting that the dt-99s will need turning down to match the scanspeaks but I don't want this to affect my crossover, an input of where to start with this would be great.
Old 10th December 2016, 11:43 AM   #3
Right the pictures,
The tl goes from the back of the driver, folds up to the front then to the back, finally exiting next to the speaker through the square port shown in the photo.
The diameter of the driver cone is 100mm so the tl is 100mx100mm
The box has 45 degree deflectors in the folds
http://i32.photobucket.com/albums/d4...ps2s5neps9.jpg
Old 10th December 2016, 12:55 PM   #4
Hope you can see that
Old 10th December 2016, 12:59 PM   #5
This shows the front with tl opening " square" then next to them bass openings
Above these are tweeters and the 2 other holes are to mount crossover bits
Old 10th December 2016, 01:44 PM   #6
This is it today, looking forward to trying the scanspeaks in it to see if it will work well or be firewood
Any advise?
Click the image to open in full size.[/URL]
Old 10th December 2016, 03:24 PM   #7
Anyone have any input on this?
Old 10th December 2016, 04:32 PM   #8
GM is offline GM  United States
GM's Avatar
Greets!
Well, based on the woofer's published specs........ to tune to Fs the cut length will be somewhat shorter and after factoring in damping, shorter still.
Tutorial: http://www.quarter-wave.com/TLs/Alignment_Tables.pdf
Excel calculator: http://www.quarter-wave.com/TLs/Alig...tor_3_3_09.xls
That said, low Qts drivers [< ~0.7] tend to perform better overall tuned to Fs/Qts, especially when end loaded, so can be even shorter.
Note that the shorter it is, the greater its area, damping density ideally needs to be to compensate for the lost net volume [Vb], so maybe no net total cab size.
Not familiar with any of the drivers, so that's it for me.
Good luck with it!
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th December 2016, 05:29 PM   #9
Originally Posted by GM View Post
Greets!
Good luck with it!
GM
Thanks for the info, ill get the matches it will be interesting to see what it is like with no stuffing
Old 10th December 2016, 05:49 PM   #10
What free pc based frequency software is recommended to look at the output?
T Line Waveguide inspired build helpHide this!Advertise here!
Thread Tools
FH3-inspired Foam Core Mini Build xrk971 Full Range 96 9th August 2018 08:23 PM
Matchless Lightning inspired build lightreel Instruments and Amps 101 11th September 2015 10:31 PM
B&W 803-inspired Zaph ZRT Build rulzahl Multi-Way 6 23rd June 2015 05:07 AM
Multiple transmission line (Ariel inspired) enclosure design andreaemme Multi-Way 0 28th March 2014 01:19 PM
Anyone build a Rondo Inspired Speaker? batsong Full Range 57 10th June 2013 10:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
