Taking measurements from an Open Baffle
Administrator
Joined 2004
Jeez, why the attitude? We're just discussing how to get good in room measurements with open baffle. The technique described by Joe K is meant for midrange, which is great. But it's not intended for woofers, it's just part of the picture.
The reflections off the wall behind the open baffle plays a huge role in the lower mids and bass. You have to measure the room interaction if you want a true picture of what's going on. This is easy to experiment with. If you have a garage, set up your open baffle speakers with their backs to the door. Listen and/or measure them with the door closed, then open the door. You have just removed the wall. Sound different? Of course. It will measure differently too. There will be a difference with monopole speakers too, but not as much. Try it, it's a fun experiment.
We looked thru the telescope, we saw just part of the solar system. Planet bass was not in the eyepiece.
