Help 8" coax project.
Old 11th December 2016, 06:18 PM   #31
Drummer 35 is offline Drummer 35  Spain
Hi again!
Been working on the cabinet design, and want to show you what I got so far.
As you can see, itīs a kind of "sandwich". An inner mdf cabinet and a front and rear solid wood panels.
Now the vent.
The vent will be screwed to the front panel, so Iīll build different sizes (25-30-35mm) so I can try different tunings.
Let me know what you think about or if you would change on that design.
Thanks!
David
Old 13th September 2018, 01:06 PM   #32
newpaton2 is offline newpaton2  Argentina
Did you ever finish the design? How did they sound?
Old 14th September 2018, 06:58 AM   #33
phase_accurate is offline phase_accurate
I own the same driver and used it for some active crossover experiments a few years ago. I used them in a small closed box and EQed them for -6 dB @ 40 Hz.
Although intended for very close-field listening that setup ate power for breakfast and max SPL was definitely lacking. But within their limits they sounded very nice with very good Imaging.
I always wanted to put those in a larger box with a 12" woofer but haven't found the time for that so far.
Charles
Old 15th September 2018, 11:08 AM   #34
Yeah, I did.
I like how they sound. Very detailed mids and good imaging, but lacks low end with a passive xover, even in a big box.
I think those speakers would benefit from using an active xover as Phase did, or use them with a 12-15 woofer. If using them alone, you will strugle getting down 60hz-65hz
The Dynamikks monitor 8 speaker, uses this same driver, but with a dopped cone. (added weight to help it reach lower freqs) I thought I could try that on mines, but Iīll have to redo the xover, and Im scared I could ruin the cones with dopping, and those are not cheap ones...
Help 8" coax project.Hide this!Advertise here!
Vintage Fullrange / Coax for OBīs or "free-air" mounted. tralalalala Full Range 13 17th January 2015 05:58 PM
COAX " cables antenna" inertial Parts 54 29th June 2013 02:07 PM
3-way center-channel using SEAS 7" coax and 7" woofers jeffreybehr Multi-Way 6 5th June 2012 01:04 PM
HELP !! Getting " Clicks " when using sPDIF coax digital out arupg Digital Source 7 11th October 2010 04:48 PM
Update on " THORS TACKHAMMER 5" coax THOR Multi-Way 17 11th July 2004 07:04 PM
