Scan Mini Monitor
Scan Mini Monitor
Old 4th November 2016, 01:10 PM   #1
harvylogan is offline harvylogan  United States
harvylogan's Avatar
Default Scan Mini Monitor
I have been considering this driver for a small (6 liter ?) sealed mini monitor for a while. Looks like it would lend itself very well for an acoustic suspension design down to about 65Hz but I have found very little on line in the way of projects for this particular driver. Anyone have any experience with it?
Matthew
https://www.madisoundspeakerstore.co...elator-woofer/
Possible tweeter suggestion
https://www.madisoundspeakerstore.co...-deep-chamber/
Old 4th November 2016, 01:23 PM   #2
krivium is offline krivium  France
Not the K 01 but the k 00:
http://www.troelsgravesen.dk/EllamXT.htm
http://www.troelsgravesen.dk/Ellam-FLEX.htm
http://www.troelsgravesen.dk/Ellam-dappo.htm
I don't have experience to built with it but i've heard some speakers with this woofer and have been pretty impressed with the low end and mid. Just don't expect them to sound like a 15".
Old 4th November 2016, 09:05 PM   #3
eriksquires is offline eriksquires  United States
eriksquires's Avatar
All I can say is I'm listening to the slightly bigger and uncoated siblings and I am in heaven as I type this.
Best,
Erik
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 4th November 2016, 09:39 PM   #4
mayhem13 is offline mayhem13  United States
Matthew
Why force it low and muddle up all that wonderful midrange with near excursion limits to 65Hz.......go subwoofer with a SEAS LROY!
Old 4th November 2016, 10:22 PM   #5
Also,the Seas small profile, deep chamber tweets are funky. I mean, the response is not very smooth. I'd rather get the smaller chamber and cross higher, especially with those 5"-ish Scanspeaks.
Old 5th November 2016, 01:40 PM   #6
harvylogan's Avatar
Not forcing the issue. I posted the excursion graph to show max power handing as modeled. Actually I do plan on utilizing these satellites with a sub crossed around 50-80Hz with a Mini DSP HD and another amp channel. The model for that is shown below and looks really good. At the same power level the Scan is still under the linear excursion rating and nowhere near the limit.
Also, I like the small form factor of the Scan 6020 but I am also considering these 2 tweeters, although the 6600 is at the upper limit of my budget.
https://www.madisoundspeakerstore.co...-textile-dome/
https://www.madisoundspeakerstore.co...h1499-tweeter/
Old 5th November 2016, 01:59 PM   #7
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Scan Mini Monitor
Matthew
I know the uncoated version of these drivers from my incarnation of the AOS Studio 24 and the PrunuScan. They are very good in the midrange, and are super easy when it comes to filter design (can do a first order filter easily). Deep and strong bass is not their strength, and I found they sound better with a high pass filter to remove the deep bass, and add a dedicated subwoofer.
If you're going with a first order filter (which I recommend!), doing the same for the tweeter would be a natural choice. So you'd need a tweeter with a lowish resonance frequency, and a sufficiently flat roll off at (and below) the x-over frequency. I really like the ScanSpeak tweeters...
Scan waveguides (elliptical / circular) MATAA audio analyser Open Source Monkey Coffin
Old 5th November 2016, 02:05 PM   #8
Face is offline Face  United States
Face's Avatar
Scanspeak's small form factor ring radiators and Be tweeters are more usable than their soft domes.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 5th November 2016, 02:37 PM   #9
harvylogan's Avatar
mbrennwa,
That PrunuScan is a beautiful speaker.
Old 5th November 2016, 03:00 PM   #10
mbrennwa's Avatar
Scan Mini Monitor
mbrennwa,
Thanks!
Scan Mini MonitorHide this!Advertise here!
Monitor or TL for Scan 18w FozzZ Multi-Way 1 1st March 2013 07:25 AM
Scan-Speak Reference Monitor gchrist Multi-Way 37 10th April 2007 10:46 PM
Scan Speak Reference Monitor keyser Multi-Way 7 13th September 2005 04:35 PM
The A4 monitor, best mini monitor? KURT Multi-Way 5 26th April 2005 01:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
