Qts and damping factor when identical drivers are used in series?
Why would or would not the DC resistance of one driver affect the Qts of the other?
Two exactly the same drivers wired in series don't change Qts over a single
unit because the ratio of the variables involved in a calculation remains the
same.
You'll find in books following formulae to calculate TS parameters once
you have recorded impedance vs. frequency.
Ro=Rmax/Re; Rmax= max value of Z at Fs
Qms=(Fs*sqrt(Ro))/(F2-F1); F2,F1=frequencies at Rx
Rx=sqrt(Re*Rmax)
Qes=Qms/(Ro-1)
Qts=Qms/Ro
