Built In the wall shallow front ported design?
Old 14th September 2016, 09:04 AM   #1
Neilkaz is offline Neilkaz
Default Built In the wall shallow front ported design?
Hi all, my first post on here so hope I don't get shot down in flames. Been dredging the posts for anything similar and can't seem to discover anything like this so hope someone can help.
I'm looking to build a pair of "in wall" speakers, yes they will be fixed into a cavity wall with just the fronts showing, this is all to do with keeping my better half happy. It isn't in a room where I intend to sit and listen to the outstanding quality of sound, it's for left and right of a 5.1 cinema setup, they aren't close to the screen so shielding isn't an issue. Something with clarity and a bit of punch would be a nice outcome.
My design constraints are only depth (which is 180mm) , width and height aren't too much of an issue although something in the ball park of 350mm H x 250mm W would make structural wall changes simpler.
My first thoughts were of a front ported two way design?? Does this seem achievable? Are designs out there already?
Response below 100hz isn't really required as the setup already has two Kef subs.
Any help or pointing in the right direction would be gratefully received.
Old 14th September 2016, 09:13 PM   #2
AllenB is offline AllenB  Australia
AllenB's Avatar
So you have 15l openings to work with? It might be possible to use multiple small woofers spanning them.
Old 14th September 2016, 09:34 PM   #3
Would that be the best option?, a "Bose" sort of solution In laymans terms.
My initial thought was a simple two way front ported box using , using a 5.25" or 6.5" driver and a good quality compression driver or ribbon . Again this is just ideas flying out my head.
Old 14th September 2016, 10:16 PM   #4
AllenB's Avatar
This definition depends on the spacing of the woofers and the space covered on the wall. They will behave differently at different frequencies with opportunities for dealing with reflections if the OP can identify the requirements and recreate them.
But if practicality is the priority then maybe power handling is the issue.
Old 14th September 2016, 10:46 PM   #5
Einric is offline Einric  United States
Einric's Avatar
I think there may be quite a few 7-8" woofers that would work well in a sealed enclosure since you already have subs to use.
You could maybe start by looking at some 2 way designs that use 7-8" woofer and discard the baffle step compensation circuits from the crossovers.
Old 14th September 2016, 10:56 PM   #6
Einric's Avatar
Check This Out
Mandolin Speaker Kit / Pr
It has a 6.5" woofer in a 2 way configuration but when vented only uses 15L of air space.
Sealed with a little less space would probably work out well for your application.
  Reply to this post
Built In the wall shallow front ported design?Hide this!Advertise here!
Shallow mid-range enclosure inside a 3-way?? too shallow?? Kooshball Multi-Way 8 3rd November 2012 11:40 PM
Dual horned sub cab ported design vs ported? matthias125 Subwoofers 14 23rd October 2012 02:44 PM
BBC Thin Wall Enclosure - Ported? Tenson Multi-Way 66 2nd July 2012 12:51 AM
shallow enclosures (on-wall) tom31415926 Multi-Way 9 25th April 2007 01:34 AM
Woofer Towers, front-ported or rear-ported? Goldenboy Multi-Way 6 15th June 2004 06:44 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
