A box that we are currently developing. Here's a picture of version 1, and a 10 meter, 28.3v ground plane measurement (biamped, 2.83v into both, 8 ohm nominal bands, passive crossover on the 4594he, 750 hz crossover, 18db/octave Butterworth lopass, 24 db/octave Butterworth hipass)
There is still some work left to do with rear chamber volume, VTC, and the transition from throat filler to horn entry to try and fill in the dip 400-600, but so far very happy with the sound of the box with no eq at all, thr 4594he is very well behaved on this horn down to 750.
Passive crossover development will begin as soon as we complete our final tweaks.
The horn in that thread features.. offset driver configuration. This is normally mounted driver
Offset driver config: as in the driver baffles are not on the same plane vs your drivers are on the same plane?
What did you change in v.2?
Are those 12s surpassing your expectations?
Would you change anything else, if there were a "next time"?
- Dual 16 ohm BC 12ndl76 +BMS 4594HE 1.4" exit coax
