Small Syns
Small Syns
Old 29th December 2019, 02:51 AM   #451
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Small Syns
They are the centers of the drilling locations. The size of the ports isn't critical, by the way, wavelengths where they are used are long. Just don't go out to beyond where the driver gaskets will be. And for best vertical pattern, I wouldn't let the height get any taller than in the drawing, want the centers as close as reasonable to the center of the waveguide. Too narrow height might possibly restrict air flow (though not likely).
That drawing is for 0.5' plywood side panels for minimum size and weight Be careful to make sure the back is well braced, maybe more than shown in the plans. My original ones were actually done with 3/4" ply, and seem quite dead, though.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Small SynsHide this!Advertise here!
Sell beatiful small 6F3 small tube amp (used like new) siliconray Vendor's Bazaar 0 1st March 2012 01:50 PM
Small room, small speakers advice c12mech Full Range 10 14th March 2011 09:36 PM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 08:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 03:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 02:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
