2-Way Vifa P17 Tymphany Horn Tweeter "VF2"
2-Way Vifa P17 Tymphany Horn Tweeter "VF2" Please consider donating to help us continue to serve you.
Old 21st March 2016, 04:15 PM   #1
JShadzi is offline JShadzi  United States
JShadzi's Avatar
Default 2-Way Vifa P17 Tymphany Horn Tweeter "VF2"
My name is Javad and I am a speakeroholic. =)
I "needed" some new front channel HT speakers for the TV room, I had these 4 Vifa P17WJ00-08 woofers, they are actually 20+ years old, hard to believe!
I picked up these Tymphany horn loaded aluminum done tweeters as they are very efficient, 8ohms and had a nice look to them.
I have a bunch of left over maple plywood from my RS4 project so undecided to glue up a bunch of the smaller pieces and make some enclosures for these woofers. You can see some seams if you look carefully.
Ports are 2.75" from Amazon, only $12 a pair prime and look very nice.
I used a simple premade passive crossover from PE at 3kHz.
They sound nice, don't hold a candle to the PS2 I finished recently but they sound great with movies and good with music. Not a lot of bass out of these woofers, they go flat to about 80 and start dropping off from there which is fine as I'll be building a subwoofer next.
Tweeters are very lively but I wouldn't say they are bright or harsh, very crisp and detailed, not bad for $20 each.
Cabinets are 28l, port tuned to about 60hz, they sit 34" tall. Stain in Varathane Ebony, finish is Minwax semigloss poly from a rattle can.
Anyway, fun project that cost less than $100, I have a total of 15 hours into them between Friday night and Saturday afternoon.
Thanks!
Old 21st March 2016, 06:52 PM   #2
Eldam is offline Eldam  France
Banned
DId you look at what Duntech made with those nice p17 ? swap for a first order filter around 4 k Hz with a Seas Excell tweeter (the one which match the 91 dB efficienty of the two P17 in // (88 db + 3 dB)
duntech.com , there was an old model, not the AMbasador but the same in the line just before (without the bass driver....
Xo in the low end was close, around 80/100 Hz.
a satori 92 dB tweeter could match also with a little resistor in serie...
Old 26th March 2016, 05:33 PM   #3
JShadzi's Avatar
No hadn't heard of them, just had these drivers and wanted to use parts I had on hand, sounding good for HT use, I just finished a center channel as well using the same tweeter, 8" Vifa M22 woofer and Dayton 2" dome mid
2-Way Vifa P17 Tymphany Horn Tweeter "VF2"Hide this!Advertise here!
"ok" to use a tweeter lower than suggested with horn/waveguide ReDress Multi-Way 12 7th February 2016 03:26 AM
Foster 025N03 Cast Aluminum Horn Tweeter 3" x 7-1/4" JohnGeneva Multi-Way 12 5th July 2012 03:07 AM
RSC (radio speakers canada) 15" woofer, 8" midwoofer, horn tweeter perceptionchanges Swap Meet 0 29th May 2010 08:18 PM
WTB: Vifa P17 poly-cone 6.5" woofer 4 OHM (pair) GordonW Swap Meet 0 31st July 2008 06:14 PM
My TL speakers with dual Vifa P17 and Heil tweeter Andypairo Multi-Way 42 14th May 2004 09:04 AM
Copyright ©1999-2019 diyAudio
