Driver for vocal
Driver for vocal
Thread Tools
Old 28th January 2016, 02:28 PM   #1
Viper_user is offline Viper_user  Sweden
Viper_user's Avatar
Default Driver for vocal
Hi!
I am searching for a driver with a frequency response between 1-6 kHz.
Is this possible with regulars or should i go for horns?
The idea is to have a upper voice range free from a x-over. Above I'm planning a slot tweeter. And for the low I already have a suitable driver.
The listening distance will be ~3,5m / 140 inches. And the price up to ~90$ /each, new or used.
Thanks for any tips!
Old 28th January 2016, 02:46 PM   #2
ewollowe is offline ewollowe  Australia
I'll try to get the ball rolling here?
Sounds like a candidate for a full/wide range drive unit?
I've heard good things about the Fountek FR88-EX.
I've seen some people use 8" paper cone units (Lowther) as their ultimate midrangers but not sure what you'd get for $90 each in Europe?
Old 28th January 2016, 03:23 PM   #3
hottattoo is offline hottattoo  United States
Keep an eye out for a pair of used 2" compression drivers. They can handle that critical rage fairly easy and can go as low as 500hz. Add a horn ( new or used ) from Autotech when you can and you will be off to a very nice start. You would have high efficiency and dynamics that cone drivers wish they had. Sometimes it pays to buy right and cry once !!!!! Another excellent driver, but not cheap is the Beyma TPL150 ( check ebay). Good luck.
Old 28th January 2016, 11:49 PM   #4
Viper_user's Avatar
Good tips! Will consider it.
Old 28th January 2016, 11:50 PM   #5
Viper_user's Avatar
Thanks for the advice. Reading around some I find this similar driver that seems to be a step up, but it comes with two different magnets.
Anyone know which one is the better? The spec are some different
Tang Band 1 W3-881SJF
Tang Band 2 W3-881SJ
Old 29th January 2016, 01:27 AM   #6
Dissi is offline Dissi  Switzerland
Those 3" cone drivers with tiny voice coils simply are not capable to produce the SPL required in home audio (>100 dB). A 2" midrange dome easily does and is perfectly suited.
Old 29th January 2016, 02:15 AM   #7
LineSource is offline LineSource  United States
LineSource's Avatar
A few modest cost 1" compression drivers(DE250) on modest size horns/waveguides (SEOS15) get good reviews covering 1Khz-18Khz with well controlled directivity.
Geddes has a paper on the value of controlled directivity speakers on his website which could change your design direction for the better. Geddes uses the B&C DE500 1" compression driver crossed at 1Khz - 18Khz on his well reviewed 15" Summa speaker.
Crossover shown here...
http://libinst.com/SEOS/SEOS15/SEOS1...5%20design.pdf
Old 29th January 2016, 02:33 AM   #8
adason is offline adason  United States
adason's Avatar
1 to 6 kHz, looks like a job for dome mid
you have not specified sensitivity you need and wattage
Old 29th January 2016, 09:35 AM   #9
zmyrna is offline zmyrna  United Kingdom
I use B&G Neo8S.
Old 29th January 2016, 12:07 PM   #10
thunk303 is offline thunk303  Australia
thunk303's Avatar
This might interest you...
http://www.diyaudio.com/forums/multi...urce-horn.html
http://nomadessentials.com.au
Driver for vocalHide this!Advertise here!
Thread Tools
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 2 6th August 2020 08:07 PM
DIY Vocal Compressor. Need Help !!! nguitar12 Instruments and Amps 4 6th January 2015 03:42 AM
Good vocal recordings phishead8 Music 68 7th February 2014 11:46 PM
Driver recommendations for vocal sound reinforcement mx2 Multi-Way 2 7th January 2008 12:15 AM
Good vocal A'af Music 0 20th January 2002 03:29 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
