a nice K-tube tweeter
Old 28th November 2015, 07:09 AM   #61
freddi is offline freddi  United States
freddi's Avatar
maybe Ann Karlson ? (JEK's widow)
Old 11th December 2015, 09:28 PM   #62
tb46 is offline tb46  United States
Hi Y'all,
I hope the bomber didn't terminate this thread. :-)
The picture in Post #54 looks like the nozzles John Karlson is holding are reducing in size towards the open end. Would that make a big difference?
Oliver
Old 16th December 2015, 08:42 PM   #63
Bill F. is offline Bill F.  United States
Bill F.'s Avatar
I'm still hoping to finish the Karlson tube project I dreamed up a couple years ago (link).
I got as far as roughing out a couple tubes, and then life got in the way. I still have a bunch of promising drivers to try out. Shouldn't be too hard to put together a multi-amped test bed with my Rane RPM88.
Old 17th December 2015, 01:20 AM   #64
Hi Bill F.
Post #63: "...multi-amped test bed with my Rane RPM88..."
Good thinking, I forgot all about the Rane MA 3s I've had on the shelf for years now. That'll help. :-)
I've been messin' w/ some cheap GRS PZ1188, just trying to find a little time, and get a few things set up to listen to. Don't have anything set up to measure w/, so largely a waste of time, but putting the large 2"I.D. cardboard K-tube over the 1"I.D. fiberglass K-tube softened the response, nearly sounds promising. I used about 1.5" of acoustic foam at the base of the K-tubes to hold and center the big tube over the little one.
File Type: jpg 2015Dec15_2in_1in_nested_ktubes_ front_side_small.jpg (36.2 KB, 223 views)
Oliver
Old 4th January 2016, 12:47 PM   #65
kees52 is offline kees52  Netherlands
Have al a happy newyear.
Somebody on trynergy threat did advise me to use a K-Pipe tweeter like this for injecting hf from 2 a 4 khz into the horn throat close to the 2 inch wideband driver.
For this I need a small pipe, on a 1 inch tweeter, I do not now what happens but maybe it is interesting.
I need to bend the pipe slightly.
Now I did put a tweeter in mouth for testing. I do like the pipe approach.
regards
Old 12th July 2019, 08:04 PM   #66
Retsel is offline Retsel  United States
Default Add in a diffuser
I know that this thread is old...
Like any speaker which beams, a diffuser could be added to the tube to help distribute the high frequencies which tend to beam. I think that the Karlson patent shows this.
Retsel
a nice K-tube tweeterHide this!Advertise here!
Seen on Craigslist: nice LCR with Vifa drivers/horn tweeter lens in Los Angeles taloyd Swap Meet 0 12th August 2015 05:51 PM
nice and simple mod on BMS tweeter Sjef Multi-Way 0 20th July 2007 09:59 AM
Looking for a nice horn/waveguided tweeter David Gatti Multi-Way 1 25th April 2007 02:20 AM
Nice little Tweeter from Vifa dkxdn Multi-Way 0 21st May 2005 10:29 AM
Nice tweeter for a 2k crossover Killjoy99 Multi-Way 28 13th July 2004 02:03 PM
Copyright ©1999-2019 diyAudio
