World's Best Tweeters Face-off :: Subjective comparison
Old 12th June 2019, 09:16 PM   #441
etalon90 is offline etalon90  Canada
etalon90's Avatar
Sold my AMT Beyma and Raal too
I must be deaf or something...
Old 12th June 2019, 09:39 PM   #442
Rewind is offline Rewind  Sweden
Rewind's Avatar
My Raals are still going strong, after being hornloaded down to 2kHz for 2-3 years. Going to add another compression driver for upper midrange to see how that sounds like. I have had an allergy for anything heavier than .001 grams-something in the high frequency for a while.
What did you go for instead? Plasma? Bluetooth portable speaker?
Old 12th June 2019, 11:45 PM   #443
LewinskiH01 is offline LewinskiH01  Argentina
Interesting. Please keep us posted. I have TPL-150H and have considered a 2" CD for the midrange but have to buy the CD and grew concerned of the center to center distance between such large tweeter and midrange, at 2kHz. Interested in learning how things pan out for you.
Old 12th June 2019, 11:59 PM   #444
Rewind's Avatar
One word. Iwata. it shrinks a large horn vertically and also has a more relaxed sound than round horns. This system has to be time-aligned in DSP for space constraints. The directivity suffers so you have to sit and stare into the throat to get good highs. And with a deep horn it is no longer in supertweeter territory. I almost need another pair of Raals above ~10kHz.
Old 13th June 2019, 01:50 AM   #445
Your nice and dark room is...eeee...dark! not sure what I should see.
Iwata was in the cards. Still seems c-to-c would be large for 2kHz xo. But then I haven't tried it.
DSP time alignment is part of the system. No problem.
I wouldn't use the CD horn above 2kHz so directionally in the treble wouldn't be that big of an issue.
How low do you plan to take the midrange horn? 2kHz down to...?
Old 13th June 2019, 07:07 AM   #446
Rewind's Avatar
Forgot to switch the light on. I will start with 1400Hz and then I don't know. People use Raal from 12kHz, but I think that is wasteful.
The Fane Studio 8M is not doing much at the moment and probably never will. The 15" will hopefully be replaced by a midbass compression driver soon.
Old 15th June 2019, 02:48 AM   #447
Starting at 1400Hz for the Raal or for the midrange CD? Rather low for the Raal and rather high for the midrange
Old 15th June 2019, 05:31 AM   #448
Rewind's Avatar
No, I mean 1400Hz or upwards for the second channel of comöression drivers. But impossible to say if I like it when the horns are done.
Old 15th June 2019, 07:34 AM   #449
celef is offline celef
Wow, those really looked like a mouth with fully lips !
Old 15th June 2019, 07:45 AM   #450
Rewind's Avatar
They have been called worse.
World's Best Tweeters Face-off :: Subjective comparisonHide this!Advertise here!
A Subjective Blind Comparison of 2in to 4in drivers - Round 4 xrk971 Full Range 742 28th October 2017 11:45 PM
A Subjective Blind Comparison of 2in to 4in drivers - Round 3 xrk971 Full Range 436 26th September 2016 04:03 PM
A Subjective Blind Comparison of 3in to 5in Full Range Drivers xrk971 Full Range 680 9th August 2016 11:52 AM
A Subjective Blind Comparison of 3in to 5in drivers - Round 2 xrk971 Full Range 461 26th July 2015 10:18 PM
WTB: Carver TFM-15CB face plate or just the plastic face plate bezel. hatrack71 Swap Meet 0 21st August 2013 05:11 PM
Copyright ©1999-2019 diyAudio
