Your next compression driver?
Old 25th May 2019, 09:43 PM   #21
ErnieM is offline ErnieM  United States
Curves
BMS 5530ND. Similar performance to their previous top of the line 1" drivers but only 72mm in diameter rather than 85mm.
Old 16th September 2019, 05:49 AM   #22
Oabeieo is offline Oabeieo  United States
Originally Posted by ErnieM View Post
Curves
Are you taking comparing to the 4552nd?
Old 16th September 2019, 10:36 AM   #23
FredrikC is offline FredrikC  Norway
Better than 1095 from 18 sound?
Old 16th September 2019, 05:53 PM   #24
Yes. Only comparing the graphs, not actual experience.
Old 17th September 2019, 01:02 AM   #25
Just found out there’s a HE model that has a shorting ring
The 5530HE , I will have a Pair on order this week
Old 17th September 2019, 01:26 AM   #26
From talking with my bms dealer it can play lower same vc and diaphragm size
He said something about the exit clearance and how it allows to go lower.
I have the 4552nd and it drops like a rock at 900hz probably at least 48db slope naturally
If I was to guess. We’ll see how this one plays.
The 2408h plays to 1k but only sounds good no lower than 1.4k with a 4th order slope.
So I’m guessing it’s basically a 4552 with more space to have excursion and a tiny tiny bit longer coil or set at a different height. (That’s a guess I don’t know the mechanics of a CD
Just going from woofer knowledge.
Anyway he said there excellent and should see them in a month
Your next compression driver?Hide this!Advertise here!
Compression driver help please chris661 PA Systems 34 16th February 2015 12:17 PM
Compression driver protection mhtplsh PA Systems 8 20th January 2014 11:40 PM
Help with suitable compression driver endrek Full Range 1 13th April 2011 03:06 AM
Compression driver watts? mhtplsh Multi-Way 9 11th September 2009 06:19 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Copyright ©1999-2019 diyAudio
