Totem Rainmaker tweeter replacement
Old 27th April 2015, 11:50 PM   #1
mdelrossi is offline mdelrossi  United States
Default Totem Rainmaker tweeter replacement
Hello,
I picked up a pair of Rainmakers. Nice speakers, definitely a different sound from Vandersteen 2c's.
I noticed one of the tweeters had been pushed in. I took it apart and pushed it back out. Sounds fine, but I inquired about replacements and the dealers are quoting me aprox $180 for one tweeter. Quite a bit more than I'd like to spend
Its a Seas H1284-06 25TA/G-TO not available any more.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Madison suggested the 27TBFC/G (H1212) $52 each, If I by two I can have enough left over for a nice dinner. . How would this change the sound?
mdr
Old 28th April 2015, 12:13 AM   #2
PeteMcK is offline PeteMcK
Link to old tweeter data:
Seas 25TA/G (6Ohm)
the 27TBFC/G is slightly more efficient, so level may need tweaking, otherwise looks like a good replacement
"A Fenderr Telecasterr has mair penetration than an AK47" - Alex Harvey
Old 28th April 2015, 12:58 AM   #3
system7 is offline system7  United Kingdom
system7's Avatar
It's a non-ferrofluid SEAS tweeter, usually designed for replaceable voicecoil so I think you may have adequately fixed it.
SEAS have been doing 26mm tweeters on 104mm cutouts for years, and I wouldn't be surprised if newer voicecoils fit older models.
IF I was replacing here, I think I'd stay true to the non-ferofluid 92dB 27TBC/G spirit:
H1147-06 27TBC/G
Some people prefer non-ferrofluid. You may want to adjust level slightly. Generally each ohm drops you a dB, so perhaps an extra ohm at the input required for replacing a 91dB unit. I like a Zobel (7.5R + 0.68uF) with metal domes to round off their sharp nature.
"Per ardua, ad astra." Best Regards from Steve in Portsmouth, UK.
Old 28th April 2015, 09:52 PM   #4
Old 14th January 2019, 04:49 PM   #5
denoxster is offline denoxster
Sorry for reviving old thread.
Did you end up replace tweeter with mentioned tweeter? How did it go?
Old Yesterday, 05:35 PM   #6
flaviowolff is offline flaviowolff
I'm also sorry to revive this old thread, but it suits my question perfectly:
I need to replace my Rainmaker tweeter. Would the matching SEAS 25TAF/G work? There are some on eBay.
I'm asking because I read that Totem modifies the tweeter somehow, so I'm afraid a direct replacement could not work... According to some websites, Totem adds a custom rear ressonance chamber. I dont know if its glued to the tweeter or not.
Any help is greatly appreciated.
Old Yesterday, 08:14 PM   #7
system7's Avatar
I am seriously considering starting up my own speaker factory. If Totem can start up some line of products called Rainmaker, maybe I should go for Widow Maker!
TBH, these people are having a laugh in suggesting their tweeters are better than anybody elses! I visited Moss, Norway years back. Nice enough place.
Tweeters are tweeters. If you are replacing something that got blown up at a Party, and to blow up a tweeter with a 5" midbass takes some effort, here's how it works:
Click the image to open in full size., here illustrated with a SEAS 19 TAF/G:
Now really, just get a new SEAS 27TBC/G: H1147-06 27TBC/G
Old Yesterday, 08:18 PM   #8
Adding to this (sorry, I didn't find the edit button), I found some images of the tweeter in question, with and without the said chamber added by Totem:
I'd like to know if this chamber is removable somehow, and swappable to a new tweeter.
Old Yesterday, 10:33 PM   #9
The totem-modified 25TAF/G appears to have a hole that the stock SEAS spare does not:
Old Today, 08:08 AM   #10
system7's Avatar
The original looks most like a modified H0831-06 27TFF. The added chamber lowers the Fs slightly. The 27TBC/G has a chamber.
I can only tell you what your options are here. Me, I'd get a new whole tweeter.
You might go to madisound and try a replacement voicecoil:
SEAS H9909 Voice Coil for H398, H400, H417
Or get a whole new unit which looks similar:
H1147-06 27TBC/G
Nothing stopping you playing with ferrofluid:
Blue Aran - The UK's no.1 Loudspeaker Component Stockist > Sonitus Audio > High Frequency Drivers > Ferrofluid
Ferrofluid is optional. It changes the impedance and frequency response slightly:
Vifa C17WH-
Level adjustments are easy enough for the cost of a ceramic resistor. I have already suggested how to do that:
Each ohm is about 1dB level change.
Totem Rainmaker tweeter replacementHide this!Advertise here!
replacement tweeter hanndoddi Parts 8 30th December 2013 01:36 AM
Totem Rainmaker Clone Einric Multi-Way 4 22nd April 2012 11:23 PM
help with replacement tweeter replacement - KLH twenty three indianajo Multi-Way 2 15th February 2010 01:54 AM
Totem Rainmaker Vs Model 1s xuchenxixu Multi-Way 0 8th June 2008 07:58 AM
Copyright ©1999-2019 diyAudio
