Eminence Alpha 6A
Eminence Alpha 6A
Old 4th April 2015, 04:50 PM   #11
technofreak is offline technofreak  Estonia
technofreak's Avatar
Send a message via MSN to technofreak
I guess 5 kHz 1st order would be a good starting point. That'll give you 3rd order acoustical. Or 2,5 kHz 2nd order if you want to use a wide dispersion tweeter (dome, ribbon or slot). No LP can work well, too, as in my case - it's almost perfect 2nd order acoustical roll-off. A slight widening of dispersion from 5 to 6 kHz isn't much of a problem (I guess this is where the dust cap makes sound).
(Damn pictures aren't showing up again. Oh, well.)
Old 4th April 2015, 05:05 PM   #12
akarma 76 is offline akarma 76
Thanks again. Really valuable information.
Old 5th December 2018, 11:52 AM   #13
swann is offline swann  Germany
Hi Folks,
i know its a very long time ago, but still i could'nt find any other measurements than the one posted on the german board.
I even did wrote this guy if he had made any degree measurements or checked some tsp before selling them but no awnser yet.
So i was wandering if anybody here had made some reliable stuff with that driver and would like to share it .
Greets Swany.
:-P
Old 5th December 2018, 06:05 PM   #14
weltersys is online now weltersys  United States
weltersys's Avatar
Swany,
The Eminence Alpha 6 measurements below were taken in 2011, not positive if they had the "A" designation.
Sealed box of around 480 cubic inches, outdoors, approximately 5 foot off the ground, on axis, and 10, 20, 30, 40, and 50 degrees off axis.
There is no smoothing in the measurement.
Art
Old 5th December 2018, 10:19 PM   #15
Thanks for the Measuerements Art! Helps...:-). I hoped beaming would start around 3 khz and it does. So ok have to build a cabinet probe to look what thd would look like around this two breaks at 2 and 3 khz. But until than i am positively optimistic that i can cross the alpha in this area.
Have to see .
Greets Swany.
:-P
Old 7th December 2018, 12:40 PM   #16
Originally Posted by weltersys View Post
Swany,
Art
Something looks off with these measurements, too much hash for properly gated outdoor measurement and that depression in the 1 to 4 kHz region doesn't look right at all. My Alpha 6 measure much smoother, even in-room. The below measurement is with tweeter crossed at ~5 kHz.
Old 7th December 2018, 01:56 PM   #17
@ Technofreak,
why did you cross the alpha this high? Beam would already starting at 3-3,5 khz. What kind of tweeter do you use?
Greets Swany.
:-P
Old 7th December 2018, 04:18 PM   #18
weltersys's Avatar
Neither of our measured responses look very similar to the curve on the Eminence Alpha 6A spec sheet ;^).
Your drivers may be a completely different production run, are they "6" or "6A"?
Yours were measured with a tweeter (and presumably some crossover), really apples to oranges anyway.
As far as "hash", seems high resolution Smaart (1.5 Hz) measurements show a bit more, even when smoothed.
Art
Old 7th December 2018, 10:21 PM   #19
Art
6A, I bought them in 2008, I think. I used these crossoverless, really more like wideband + supertweeter style than "normal" 2-way. I have to dig around in my old files, there should be some measurements without tweeter.
I used Celestion HF 50 which is a narrow dispersion bullet tweeter (around 60 degrees conical), so that this high crossover point worked quite well. These were my old speakers back from when I was a poor student, and I was coming from 8" full range drivers. I wanted similar sound to the fullrange drivers, but with smoother mids, deeper bass and cleaner highs - mid driver that could cover from 300 to 5000 Hz and minimalist crossovers were the design points.
I also attached a measurement from some German site which name I've long forgotten.
Old 8th December 2018, 11:55 AM   #20
Its from there: Eminence Alpha-6A | Jobst-Audioshop
He's known for nice DIY-Building Speakers in Germany. Makes his own measurements too, strange that i did not find any of this before :-D.
Here is the speaker he mentioned, a small dual 6 inch with the baby bms crossed around 2 khz JL-sat26 (LMT-261) - PA Topteil fur Kleinbeschallung | Jobst-Audio - Tontechnik
Maybe i should write him and aks if he's got any off-axis measurements....that i can post here as well...:-D.
Swany.
:-P
Eminence Alpha 6AHide this!Advertise here!
Eminence Alphalite 6A neo drivers (lot of 8) JohnsonAV Swap Meet 0 10th November 2014 10:09 PM
Eminence Alpha 15a thisisvv Swap Meet 3 3rd January 2013 05:10 PM
FS: Xfmrs: 6.3VAC @ 6A, 80VAC (CT) @ 6A stoc005 Swap Meet 0 1st January 2010 11:47 PM
Eminence Alpha 10 chris661 Subwoofers 16 1st March 2008 10:43 AM
WTB: USED eminence alpha 10 kan3 Swap Meet 0 31st December 2003 10:12 PM
