Open Baffle woofer what is important?
Open Baffle woofer what is important? Please consider donating to help us continue to serve you.
Old 11th April 2017, 01:27 PM   #101
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Sorry, haven't given you the full story. The jordans have a removable back panel so I can use them OB as well, which is what I'm doing at the moment. I have active LR4 crossover at 125Hz. The U frames are 12" deep
Old 25th May 2018, 04:43 AM   #102
hazard500 is offline hazard500  Australia
Originally Posted by evershumi View Post
try to find this speakers Speaker Detail | Eminence Speaker
My audio buddy built u-frames with 2 Emince Beta 15 A in each frame. We measured FR with REW and he is getting bass more or less flat down to 30Hz without any EQ. He previously had magneplanar tympanis and acoustats in the same smallish room and I always found them a bit boomy. Be obviously he has some serious room gain around 30hz that just happens to offset perfectly the roll off of his u frame. Good luck rather than good management!
Old 13th November 2019, 09:45 AM   #103
sujat is offline sujat  India
Originally Posted by bzfcocon View Post
I think Vas has in itself less relevance in OB context, because Vas is a measure of equivalent air compliance that determines the a driver + enclosure Fs and Q. For OB, there is no enclosure.
Vas is given by the driver's stiffness and the latter is linked to the driver's Fs via it's mass. In the context of open baffle, it makes more sense to look at things from Fs and Qts perspective.
Bzfcocon, Vas as such may be irrelevant in OB, but since Vas is a direct function of stiffness (rather of compliance, which is reciprocal of stiffness), would Cms not be a factor to consider as far as how EASILY the driver would reach Xmax? For eg: if Cms for a given driver is quite high.. it might reach Xmax at much below required SPL.
Am i thinking on the right line?
Old 13th November 2019, 10:41 AM   #104
wonderfulaudio is offline wonderfulaudio
Sujat, Why dont you simulate the influence of Cms?
Old 13th November 2019, 10:57 AM   #105
bentoronto is online now bentoronto  Canada
Originally Posted by hazard500 View Post
... he is getting bass more or less flat down to 30Hz without any EQ. He previously had magneplanar tympanis and acoustats in the same smallish room and I always found them a bit boomy. Be obviously he has some serious room gain around 30hz that just happens to offset perfectly the roll off of his u frame. Good luck rather than good management!
I had a similar experience with a very large OB baffle.
Many members here are keen to be free of box sound and enhance the ambience and are pondering OBs. (See the discussion about ditching spatial localization in The Lounge forum.) But they are worried about the emanations from the rear of the drier sneaking around and annihilating the front emanations.
With an OB, you can install a driver with a low resonance and - unlike sealed boxes - it doesn't change. So you might be getting a boost in output at say, 25-35 Hz, just where you might like to hear it.
Hardly any "room gain" worth mentioning except in hermetically sealed cars. However, rooms have eigentones. But it depends on your seat location and the speaker location as to whether that will add or subtract at a given frequency. I think we notice the add-places more.
B.
HiFi aspirations since 1957. "When the toilet paper of Experience is depleted, the backside of Reason goes unwiped"
Old 13th November 2019, 12:27 PM   #106
@ wonderfulaudio: i would like to. However, i haven't found any application that will for android phone (which i can do lying down); and health doesn't much permit using a proper computer either standing or sitting.
Open Baffle woofer what is important?Hide this!Advertise here!
PRV Open Baffle Woofer? mortron Multi-Way 5 8th January 2013 11:32 PM
Found new open baffle woofer? lenta Multi-Way 8 24th November 2010 08:26 AM
Open Baffle Suited Woofer Suggestions Tenson Multi-Way 34 14th March 2006 04:29 AM
Open baffle Woofer Characteristics Peter Menting Multi-Way 17 22nd November 2003 03:51 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
