singing x-over
I was testing one of my x-overs on the bench. Hooked up the woofer leads, low pass working. Hooked up the tweeter leads and had extremely little sound output. Figuring that something was amiss, I disconnected the tweeter leads. Well I still heard music, with NO drivers hooked up. The only thing that I can attribute this to is one of the coils ? Anyone see this before ?
Yup, coils interact. :D
Placement of coils in crossover networks
This setup produced a high-pitched whine from the tweeter. The multimeter produces an approx 1kHz test tone to measure inductance in the 1mH ferrite coil. There is an effect from the metal ground plane too. A silver ashtray in this case. Hence 0.827mH reading.
I appreciate the replies gentleman.I took the x-over apart and started from scratch.I had 9 components crammed onto a 4x4 inch board. I placed the larger coil flat,and the smaller coil on its side.Made sure I had no cold solders or shorts. Tested on the bench,works and sounds good.
"I am not an electrical engineer,but have some knowledge of electronics. But I am having trouble understanding how a cap (poly) could reproduce sound."
Caps are a bit piezo-electric.
"the caps will sing without drivers connected"
Yes, in a 12dB crossover. The unloaded network is a dead short at its resonant frequency, so a lot of current is flowing.
